Nexus 7010 and NetApp Etherchannel Issue
ckeithjones
I  currently have an etherchannel configured between my Nexus and a NetApp device. I have two 4-port etherchannels that are set for LACP (mode active) that are working and 1 2-port configured exactly the same that won't work.
12    Po12(SU)    Eth      LACP      Eth1/17(s)   Eth1/18(P)
I turned on LACP error debugging and the error I get when I shut the Eth 1/17 interface and bring it back up is:
2012 Jun 15 14:09:46.731141 lacp: lacp_proto_suspend_secondary_ports(2049): Ethernet1/20(0x1a013000): Got port with non matching lag selection
2012 Jun 15 14:09:46.731177 lacp: lacp_proto_suspend_secondary_ports(2050): Port LAG=[(1, 2-a0-98-1c-a7-3e, 1, 0, 4), (8000, 40-55-39-25-75-41, c, 8000, 114)]
2012 Jun 15 14:09:46.731200 lacp: lacp_proto_suspend_secondary_ports(2052): Port channel LAG=[(1, 2-a0-98-1c-c7-86, 1, 0, 0), (8000, 40-55-39-25-75-41, c, 0, 0)]
The configuration of the ports:
interface Ethernet1/17
  description NetApp NAS
  switchport
  switchport access vlan 2
  storm-control broadcast level 1
  storm-control multicast level 1
  channel-group 12 mode active
  no shutdown
interface port-channel12
  description TSG-NAS5 Etherchannel
  switchport
  spanning-tree port type edge
Any ideas of why lacp is having this issue?
Keith
glen.grant
Missing spanning tree port type edge on the port itself.
Looks like that got rid of the lacp error messages. I turned on etherchannel debugging and now I get this when shut/no shut on the port.
7010(config-if)# show port-2012 Jun 16 07:49:30.425278 eth_port_channel: pcm_eth_port_ac_drop_all_txns(897): Interface Ethernet1/17 suspended by protocol
2012 Jun 16 07:49:30.425317 eth_port_channel: pcm_proc_response(403): Ethernet1/17 (0x1a010000): Setting response status to 0x402b000c (port not compatible) for MTS_OPC_ETHPM_PORT_BRINGUP (61442) response
2012 Jun 16 07:49:30.425457 eth_port_channel: pss_create_mbr_tlv(330): Not writing type 3 to mbr pss
tarkawa
Same problem with same errors but I just fixed it.  I had 2 Po's with 2 int's each.
Po55     Po56
e1/17     e1/19
e1/18     e1/20
One int in each Po was in suspnd.  I deleted Po56, defaulted both int's (19 & 20), added ints 19 & 20 to channel-group 55. This time when doing a "sho port-c sum" Po55 showed int's 17 and 19 up and working. Int's 18 and 20 were in suspnd.  I configured Po56 with int's 18 and 20 and it came up.
Basically, it looks like the cables may have been mixed up.
