C3650 WebUI : How to select an interface range
renArD
Frequent Visitor
Frequent Visitor
Hi everybody,
I recently discovered the nice Web UI which is built in the last os (Release Fuji-16.9.6 MD). I have just a dumb question : how can I configure an interface range in the WebUI (like the CLI command "int range")? I didn't see any way to "select" multiple interfaces to apply a common setting on them (like disabling them).
9 Replies 9
balaji.bandi
may be left side select button of multple interface - cant remember (if that option works?)
BB
Thank you very much for your answer !
However, I can't find what you say :
Do you know where to go?
Hello
Have you tried a different Web Browser?
Kind Regards
Paul
Thanks for your reply. The interface is the same among compatible browsers. Do you have, on your side, a way to select multiple interfaces?
LJ Gabrillo
Level 10
Level 10
What is your goal in selecting multiple interfaces? As far as I know you CANNOT select multiple interfaces on the interfaces view when configuring stuff in the Web GUI
Thanks for your reply!
The goal is simply to apply the same setting to multiple interfaces at once. The typical example is to deactivate them in a raw. Doing it one by one is quite annoying.
ATB
thieppt
Community Member
Can you tell me the default password to the webui of the 3650 24TS-S series. Thanks
no username (leave empty)  password is cisco  on if this was default
BB
renArD
Frequent Visitor
Frequent Visitor
You should use the user/pass set with "username webui privilege 15 secret cisco" (you can change the username and password)
