Monitor Session on C9500-24Y4C
ScottDawson2051
Hi All - Trying to setup a monitor session on my C9500 running switch stack virtual , trying to use vlans as the source but can only add 5 before I get the "unrecognised command" error message.
Running Gibraltar 16.12.0
Core_Switch(config)#monitor session 1 source vlan 32 , 34 , 36 , 38 , 42 , 44 , 46 ?
% Unrecognized command
Core_Switch(config)#monitor session 1 source vlan 32 , 34 , 36 , 38 , 42 ?
, Specify another range of VLANs
- Specify a range of VLANs
both Monitor received and transmitted traffic
rx Monitor received traffic only
tx Monitor transmitted traffic only
All the documentation I can find says 32 vlans max so is this a bug ?, IOS limitation ? or hardware limitation ?
balaji.bandi
Sure looks for me Bug :
Instead ? - if you press enter will that take that syntax ?
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-10/configuration_guide/nmgmt/b_1610_nmgmt_9300_cg/configuring_span_and_rspan.html
BB
