C3750 Code Upgrade?
Hello guys,
I want to upgrade IOS for my production core 3750 switch.Below is Show version/fash output..
I have IOS image "c3750-ipservicesk9-mz.122-55.SE7" could you please confirm below concerns-
1-As this is stackable switch do i need to upgrade on all Switch..i can see there are 3 flash while doing show flash?
2-Is above IOS image support with  my switch? do i able to enable ssh?
3-is flash memory is enough to succefully upgrade IOS?
4-Any other point which i should keep in mind before upgrading..any special feature which this IOS wont support.
Please provide expert inputs..being Production Switch i am little bit more careful...thanks Indeed!
core-sw1#sh version
Cisco IOS Software, C3750 Software (C3750-IPBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 19:15 by nachen
Image text-base: 0x00003000, data-base: 0x01080000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEC, RELEASE SOFTWARE (fc4)
core-sw1 uptime is 21 weeks, 3 days, 7 hours, 2 minutes
System image file is "flash:c3750-ipbase-mz.122-35.SE5/c3750-ipbase-mz.122-35.SE5.bin"
cisco WS-C3750-48TS (PowerPC405) processor (revision N0) with 118784K/12280K bytes of memory.
Processor board ID CAT1123NHSV
Last reset from power-on
2 Virtual Ethernet interfaces
96 FastEthernet interfaces
32 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:1B:0D:BC:AD:00
Motherboard assembly number     : 73-9680-10
Power supply part number        : 341-0028-02
Motherboard serial number       : CAT112355SS
Power supply serial number      : LIT11200BWW
Model revision number           : N0
Motherboard revision number     : B0
Model number                    : WS-C3750-48TS-S
System serial number            : CAT1123NHSV
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CAT11205FJ7
Top Assembly Part Number        : 800-25854-02
Top Assembly Revision Number    : F0
Version ID                      : V05
CLEI Code Number                : CNMV300CRE
Hardware Board Revision Number  : 0x01
Switch   Ports  Model              SW Version              SW Image
     1   24     WS-C3750G-24T      12.2(35)SE5             C3750-IPBASE-M
*    2   52     WS-C3750-48TS      12.2(35)SE5             C3750-IPBASE-M
     3   52     WS-C3750-48TS      12.2(35)SE5             C3750-IPBASE-M
Switch 01
Switch Uptime                   : 21 weeks, 3 days, 7 hours, 12 minutes
Base ethernet MAC Address       : 00:1E:BE:24:91:00
Motherboard assembly number     : 73-9679-10
Power supply part number        : 341-0048-03
Motherboard serial number       : FDO11490EJE
Power supply serial number      : LIT11360KYE
Model revision number           : M0
Motherboard revision number     : C0
Model number                    : WS-C3750G-24T-S
System serial number            : FDO1149Y2MD
Top assembly part number        : 800-25855-01
Top assembly revision number    : G0
Version ID                      : V05
CLEI Code Number                : COMR100BRA
Switch 03
Base ethernet MAC Address       : 00:1C:B0:C5:1B:00
Motherboard serial number       : CAT11255G0D
Power supply serial number      : DTN11251052
System serial number            : CAT1125NKJJ
SFP Module revision number      : A0
SFP Module serial number        : CAT112452W7
Top assembly part number        : 800-25854-02
Top assembly revision number    : F0
Version ID                      : V05
Configuration register is 0xF
core-sw1#
show Flash-
core-sw1# sh flash1
Directory of flash1:/
    2  -rwx         616   Mar 1 1993 10:31:26 +10:30  vlan.dat
    3  -rwx           5  Apr 29 1993 15:08:27 +09:30  private-config.text
    5  drwx         192   Mar 1 1993 10:36:29 +10:30  c3750-ipbase-mz.122-35.SE5
  509  -rwx       13155  Apr 29 1993 15:08:27 +09:30  config.text
15998976 bytes total (6356480 bytes free)
core-sw1# sh flash2
Directory of flash:/
    2  -rwx         616   Mar 1 1993 10:31:22 +10:30  vlan.dat
    3  drwx         192   Mar 1 1993 10:39:30 +10:30  c3750-ipbase-mz.122-35.SE5
  508  -rwx       13155  Apr 29 1993 15:08:27 +09:30  config.text
  509  -rwx           5  Apr 29 1993 15:08:27 +09:30  private-config.text
core-sw1# sh flash3
Directory of flash3:/
    3  drwx         192   Mar 1 1993 10:40:12 +10:30  c3750-ipbase-mz.122-35.SE5
  507  -rwx       13155  Apr 29 1993 15:08:27 +09:30  config.text
  508  -rwx           5  Apr 29 1993 15:08:27 +09:30  private-config.text
core-sw1#
thanks you for all your help.
11 Replies 11
Leo Laohoo
Your switch stack can support IOS version 12.2(55)SE7.
Stay with this version as it's one of THE MOST STABLE version.
Thanks for your reply...does it mean IOS which i have is not stable and i should be not using this--
i have c3750-ipservicesk9-mz.122-55.SE7 image dowanloaded...could you please comment?
-Prashant
Your IOS, version 12.2(35)SE5, is very, very, very old.  I have no idea how many security vulnerabilities have been discovered with this version alone.
I'm saying that 12.2(55)SE7 is a very STABLE version and I also highly recommend this version.
David Flatley
Community Member
  Though does the poster not have a problem with the recommended version if using the tar file since it is over 16 megs in size and the flash size on the 3750 is 16 megs???
The IOS version 12.2(55)SE7 is supported in 3560/3750 with only 16 mb of flash space.
Make sure you download the c3750-ipserviceslmk9 version instead of c3750-ipservicesk9, as the lmk version will fi on to 16M flash, also i see you are going from ip base to ip services so in the
Archive command  you must allow feature upgrade eg:
archive download-sw /overwrite /allow-feature-upgrade ....file path /c3750-ipserviceslmk9-tar.122-55.SE7.tar
Thanks for Reply..
I  have 16 MB ram and IOS image "c3750-ipservicesk9-mz.122-55.SE7" is of 12.5 MB.so while upgrading i can remove existing IOS image and put this.
can you guys suggest me if this doesn't possible or any other concern? Being production Switch i just want to reconfirm all points.
On other note,as this is satcked switch do we need to upgrade to all switches?
Prashant
With the maintanance window you have to remove the existing IOS and can put the new in all the switches in stack.IOS must be same in all the switches in stack.
Firstly, before you begin the upgrade, you need to ensure that your TAR file isn't corrupt.  The most efficient way is to compare the MD5 hash of the file against the MD5 hash from the Cisco website.
To upgrade the IOS and remove the old IOS, use the automated command:  archive download-sw /over tftp:///IOS.tar
Ah this is interesting, the tar file for 12.2 55(SE7) is 12 megs for the 3750 and the 12.2 55(SE7) for the 3750G is 16 megs. 3750 having 16 meg flash and the 3750G having a 32 meg flash. The appender has two 3750's and one 3750G so they have to use the 12 meg express tar file. Will this have an adverse effect to the 3750G ??  I find this ineresting because I have a stack with the 3750 as master and a 3750G as a member and I am running the 12.2 - 35 flash on my stack. I was going to add a 3750X to my stack but seeing how I have same flash issue I am going to remove the 3750 so the 3750G becomes the master, update the flash and add the 3750X so I have the 3750G master and the 3750X as a member.
   Thanks.
Release Notes for the Catalyst 3750, 3560, 2960-S, and 2960 Switches, Cisco IOS Release 12.2(58)SE1 and Later
Not all Catalyst 3750 and 3560 switches can run this release. The models listed below are not supported in Cisco IOS Release 12.2(58)SE1 and later. For ongoing maintenance rebuilds for these models, use Cisco IOS Release 12.2(55)SE and later (SE1, SE2, and so on).
•WS-C3560-24TS
•WS-C3560-24PS
•WS-C3560-48PS
•WS-C3560-48TS
•WS-C3750-24PS
•WS-C3750-24TS
•WS-C3750-48PS
•WS-C3750-48TS
•WS-3750G-24T
•WS-C3750G-12
•WS-C3750G-24TS
•WS-C3750G-16TD
