Bookmark
Subscribe
407
More 3750 QoS Problems
Mark Bowyer
Ok, I can see that my traffic is hitting the right queues, but it doesnt seem to be taking priority over other traffic, either that or it is being limited somewhere. I am marking video with dscp 34, voice with dscp 46 and control with 24. I have done several test calls using 2 video conferencing units. I have applied QoS on all devices in the path. The units I am testing on are only seperated by 1 WAN link. I have looked at my queues  and thresholds etc, but I cant understand what the hell is going on. I am doing file transfers to top the link out and on the video conferencing unit its self, I am seeing a lot of receive packet loss and a very small amount of transmit packet loss. Can anyone see from my config what might be going wrong with the queues and thresholds etc?
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2  1
mls qos srr-queue input cos-map queue 1 threshold 3  0
mls qos srr-queue input cos-map queue 2 threshold 1  2
mls qos srr-queue input cos-map queue 2 threshold 2  4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3  3 5
mls qos srr-queue input dscp-map queue 1 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3  0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3  32
mls qos srr-queue input dscp-map queue 2 threshold 1  16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2  33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2  49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2  57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3  40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3  5
mls qos srr-queue output cos-map queue 2 threshold 3  3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3  2 4
mls qos srr-queue output cos-map queue 4 threshold 2  1
mls qos srr-queue output cos-map queue 4 threshold 3  0
mls qos srr-queue output dscp-map queue 1 threshold 3  34 40 41 42 43 44 45 46
mls qos srr-queue output dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3  48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3  56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3  16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3  32 33 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1  8
mls qos srr-queue output dscp-map queue 4 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3  0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
class-map match-any voice
match ip dscp 46
class-map match-any video
match ip dscp 34
class-map match-any control
match ip dscp 24
class-map match-any control-VoIP
match ip dscp 26
policy-map vvc-map
class voice
trust dscp
class video
trust dscp
class control
trust dscp
class control-VoIP
trust dscp
****Interface config****
priority-queue out
service-policy input vvc-map
acampbell
Mark,
Try enabling ingress Q2 as the priority Q
mls qos srr-queue input priority-queue 2 bandwidth 30
! Q2 is enabled as a strict-priority ingress queue with 30% BW
From the link I sent you before
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND_40/QoSCampus_40.html#wp1098448
Cisco suggest that you look at your q-ing and map your selected cos & dscp values
! This section configures the ingress queues
C3750-E(config)#mls qos srr-queue input bandwidth 70 30
! Q1 is assigned 70% BW via SRR shared weights
! Q2 SRR shared weight is ignored (as it has been configured as a PQ)
mls qos srr-queue input buffers 90 10
! Q1 is assigned 90% of queuing buffers and Q2 (PQ) is assigned 10%
mls qos srr-queue input threshold 1 80 90
! Q1 thresholds are configured at 80% (Q1T1) and 90% (Q1T2)
! Q1T3 is implicitly set at 100% (the tail of the queue)
! Q2 thresholds are all set (by default) to 100% (the tail of Q2)
! This section configures ingress CoS-to-Queue mappings (if required)
mls qos srr-queue input cos-map queue 1 threshold 1 0 1 2
! CoS values 0, 1 and 2 are mapped to Q1T1
mls qos srr-queue input cos-map queue 1 threshold 2 3
! CoS value 3 is mapped to ingress Q1T2
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
! CoS values 6 and 7 are mapped to ingress Q1T3
mls qos srr-queue input cos-map queue 2 threshold 1 4 5
! CoS values 4 and 5 are mapped to ingress Q2 (the PQ)
! This section configures ingress DSCP-to-Queue Mappings
mls qos srr-queue input dscp-map queue 1 threshold 1 0 8 10 12 14
! DSCP DF, CS1 and AF1 are mapped to ingress Q1T1
mls qos srr-queue input dscp-map queue 1 threshold 1 16 18 20 22
! DSCP CS2 and AF2 are mapped to ingress Q1T1
mls qos srr-queue input dscp-map queue 1 threshold 1 26 28 30 34 36 38
! DSCP AF3 and AF4 are mapped to ingress Q1T1
mls qos srr-queue input dscp-map queue 1 threshold 2 24
! DSCP CS3 is mapped to ingress Q1T2
mls qos srr-queue input dscp-map queue 1 threshold 3 48 56
! DSCP CS6 and CS7 are mapped to ingress Q1T3 (the tail of Q1)
mls qos srr-queue input dscp-map queue 2 threshold 3 32 40 46
! DSCP CS4, CS5 and EF are mapped to ingress Q2T3 (the tail of the PQ)
Then read further on for output Qs
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
