C3750 Dhcp pool static IP
srikanth ath
Level 4
Level 4
Im using wifi connected to C3750 catalyst switch , switch is the DHCP server for the vlan created 101
Here are my configuaration:
ip dhcp excluded-address 10.10.30.1 10.10.30.10
! ip dhcp pool init
   network 10.10.30.0 255.255.255.0
   default-router 10.10.X.X
   dns-server 10.10.X.X 8.8.4.4
ip dhcp pool SR
   host 10.10.30.151 255.255.255.0
   client-identifier 01ac.7289.0d86.67
   client-name Client1
interface Vlan101
description internal userwifi
ip address 10.10.30.1 255.255.255.0
im using WI-fi to the vlan assigned
verification:
wavel3#sh ip dhcp binding
IP address       Client-ID/              Lease expiration        Type
                 Hardware address
10.10.30.11      01ac.7289.0d86.67       Mar 03 1993 11:13 PM    Automatic
10.10.30.151     01ac.7289.0d86.67       Infinite                Manual
Its taking automatic IP to the client machine connected to wifi
i need to get the manual IP assigned to the loop, any suggestions will be appreciated
where am i going wrong in this scenario.
I have about 40 client machines and all have to get the ip Mac based static assigned to the pool.
Thanks & regards
Srikanth
8 Replies 8
johnlloyd_13
Level 9
Level 9
hi,
try re-configuring as per below and try again. don't forget to do a clear ip dhcp binding.
ip dhcp pool SR
   client-name SR
done withe chages as above mentioned created the pool name and client name same .but the client is getting the ip 10.10.30.11 where he should get 10.10.30.151.
! ip dhcp pool init
ip dhcp pool SR
   client-name SR
interface Vlan101
help me out please?
thanks and regards
srikanth
cadet alain
You say it is taking the other IP from the output of sh ip dhcp binding or from ipconfig/all on machine?
Regards.
Alain.
Problem fixed. its working now . as i reebooted the Wireless Access points.
now the new problem arises. i got to add about 40 mac-address so i need to use 40 ips.
if i excluded all oter IPs still client can get the ip from excluded address
ip dhcp excluded-adress 10.10.30.50 10.10.30.254
is this is the correct way  to configure. as i only need 40 ips from the network of 10.10.30.0 as for security i need to give static ips to only 40 laptops not to any other devices used internal network.
hope u got my point can any one show me the way to configure or is ther any other security method i can take or configure in L3 switch. t prevent access other than 40 laptops...
thanks & regards
srikanth
if the machine acquired an ip from dhcp before you madse these changes then of course you must release and renew your lease on the clients.
You want 40 IPs as statically configured  and no other machine should get a DHCP address? is that so?
then excluding these IPs from the range seems ok.
Regards.
Alain
HI Alain
thanks for the update, will reply if i had problem with it..
Thanks & regards
srikanth
the problem persits i have excluded  ips for and given only 10 ips in a network range for the vlan WIFI client usage
but almost 20 people can get the IP  from it..and accessing internet ...
IP dhcp excluded-address 10.10.30.4 10.10.30.141
ip dhcp excluded-address 10.10.30.152 10.10.30.255
! ip dhcp pool init
ip dhcp pool SR
   client-name SR
interface Vlan101
problem with the Switch configuration .or WIFi access point anyhow the simple point is we have excluded ipaddress in dhcp in L3 switch right. but still the client can get an ip from exluded ip list ..where should it be. the problem.
THanks and regards
Srikanth
they shouldn't  get an excluded-address.
Clear all dhcp bindings stop dhcp service, release IP on client misbehaving
fire up a sniffer like wireshark and  restart DHCP service on switch, renew IP and post pcap file.
Also post output of sh run | s dhcp
Regards.
Alain.
