09-23-2011 08:20 AM - edited 03-07-2019 02:24 AM
Hello all,
I'm making a WiFi network using PPPoE to register all clients.
I'm having problems to use a Cisco Catalyst 2900XL Switch to concentrate all WiFi APs with the PPPoE server.
If I connect the AP directly to the PPPoE server, it works perfectly, but if I connect the AP to the switch and then the PPPoE server to the switch too, it stop working and cant connect from the client to the PPPoE server.
A really bad draw about it:
WiFi
Client Station (-- - - - --) Base Station -> PPPoE server. || This works perfectly. I can connect a computer to the Client Station RJ45 port and can create and use a PPPoE connection without problem.
WiFi
Client Station (-- - - - --) Base Station -> Cisco Catalyst 2900XL <- PPPoE server.
The computer connected to the Client Station cant anymore connect to the PPPoE server.
What I'm doing wrong?
Thanks in advance.
Solved! Go to Solution.
09-23-2011 09:06 AM
Daniel,
A couple of suggestions:
Give it a try and let us know.
Best regards,
Peter
09-23-2011 08:43 AM
Hello Daniel,
Can you post the configuration of the switch? Also, what is the type of the WiFi AP? I assume it is not using any sort of VLAN tagging on its Ethernet port, right?
Best regards,
Peter
09-23-2011 08:54 AM
Hello Peter,
This is my actual running-config:
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log datetime
service password-encryption
hostname CAT-CLI-TORREVIEJA
enable password 7 ****
ip subnet-zero
interface FastEthernet0/1
duplex full
interface FastEthernet0/2
duplex full
speed 100
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
duplex full
speed 100
interface VLAN1
ip address PublicIPAddress 255.255.254.0
no ip directed-broadcast
no ip route-cache
no ip http server
logging facility local4
snmp-server engineID local 0000000902000002FD34D540
snmp-server community **** RO
snmp-server community **** RW
line con 0
password 7 ***
login
transport input none
stopbits 1
line vty 0 4
password 7 ****
login
line vty 5 14
password 7 ****
login
line vty 15
login
ntp clock-period 22518026
ntp server 130.206.3.166
end
Sorry but I dont know if the AP does any kind of VLAN taggin. Its a Ubiquiti one.
09-23-2011 09:06 AM
Daniel,
Best regards,
Peter
09-23-2011 09:18 AM
Thank you very much Peter, Im really a dumb. Was the manually configured speed and duplex. Its an old switch we had
gathering dust in the warehouse and didnt notice the speed/duplex configuration.
Thank you very much.
09-23-2011 09:23 AM
Daniel,
No problem at all. You are welcome. I am glad it worked.
Best regards,
Peter
