C3750 - VSS question
lowclear
When using the redundancy force-switchover command in the case of the vss failover command of equipment C4500, how can I apply the same command of equipment 3750?
2 Accepted Solutions
Leo Laohoo
reload slot <1 to 9>
@lowclear wrote:
The function of this command is to switch active to standby, but why is that function rebooting active?
On a VSS, the "redundancy force-switchover" instructs the ACTIVE to "hand over" to the secondary.  This done by causing the PRIMARY to reboot.
Like I said, the exact command is not supported but the behaviour is the same as instructing the Primary/Master switch to reboot.
5 Replies 5
Leo Laohoo
So the redundancy force-switchover command doesn't work on the C3750V2 ?
The "exact" command, no.
For that same behaviour, use the "reload slot <MASTER SWITCH 1>" and the behaviour is the same, i.e.  The command will reboot the switch master.
What I'm curious about is,
Does active and standby change when the redundancy force-switchover command is applied to 3750v2 equipment?
2. If that command is not applied, what commands do the same function?
Thank you for your help.
