C3750
adam.strobel
I'm setting up a C3750 48 port switch in an IDF that connects to our 4006 switch in our MDF. Question is connecting the two switches together VIA fiber does the uplink on both ends have to be a trunk port? "switch port mode trunk" or "switch port mode access"? Also both these switches and ports are on the same vlan.
I?m confused as to which commands to use at what times,
Switch port mode trunk and switch port mode access. I understand that access is for connecting hosts and trunks are used for carrying multiple vlan traffic but I have seen both commands used at different times.
Adam
Adam,
Your understanding of access/trunk modes is partially correct. Access mode doesn't have to be necessarily connecting hosts. Ports connecting switches can be set to access mode as well if the port doesn't have carry traffic for multiple VLANs.
If you specify the mode to be access then the port would never become a trunk port under any circumstance. It's better if you can set the mode to access/trunk without having the port dynamically form access/trunk association on that port.
The two modes can be configured as follows:
Switchport Access Mode:
int f0/1
switchport mode access
switchport access vlan 10
Switchport Trunk Mode:
int f0/1
switchport trunk encapsulation (isl/dot1q)
switchport mode trunk
Sundar
pkhatri
Level 11
Level 11
Adam,
You need to use 'switchport mode trunk' if you want it to come up as a trunk link. The commands are mutually exclusive and you should not be able to configure both at the same time.
Paresh
PS. Pls do remember to rate posts
thanks Paresh, what would it mean if I configured it as an access link?
Adam,
int f0/1
int f0/1
Sundar
