Policy based routing on 3750
mspiegelman
Im trying to set a a policy route on a VLAN interface on a 3750 running 12.2.25(SEE) advanced.
After entering the vlan interface I type:
ip policy route-map pbr
I get no complaints but the line doesn't show up in the config. What am I missing? Does the 3750 support policy routing?
pkhatri
Level 11
Level 11
To use PBR, you must first enable the routing template by using the sdm prefer routing global configuration command.
Paresh.
PS. Pls do remember to rate posts
pkhatri
Level 11
Level 11
Paresh.
