C3850 - Disabled Password Recovery not vissible in configuration
danielbarri
When a 3850 is configured with:
Switch(config)# system disable password recovery switch all
This configuration line is not visible when running "show running-config [all]" or "show bootvar"
How do I figure it out if the password recovery is enabled or disabled?
The c3850  "Disabling Password Recovery" documentation says:
This setting is saved in an area of the flash memory that is accessible
by the boot loader and the Cisco IOS image, but it is not part of the
file system and is not accessible by any user.
Does it mean that the password recovery configuration won't be visible anywhere? But still I need to know if "password recovery" is on/off
It seems that the "password recovery" settings are only visible at rommon:
When we disable password recovery on switch, the ROMMON variable “SWITCH_DISABLE_PASSWORD_RECOVERY” indicates 1 and when we enable password recovery, it indicates 0. By default password recovery is enabled on switch.
Disabling password recovery-
Switch(config)#system disable password recovery switch all
Applying config on Switch 1...[DONE]
Applying config on Switch 2...[DONE]
Applying config on Switch 3...[DONE]
Switch: set
<SNIP>
SWITCH_DISABLE_PASSWORD_RECOVERY=1  <<<<< This indicates password recovery is disabled
SWITCH_IGNORE_STARTUP_CFG=0
SWITCH_NUMBER=1
<SNIP>
Now trying to enable password recovery
Switch(config)#no system disable password recovery switch all
switch: set
<SNIP>
SWITCH_DISABLE_PASSWORD_RECOVERY=0  <<<<< This indicates password recovery is enabled
SWITCH_NUMBER=1
<SNIP>
Switch-3850s#sh run |  i password recove
Switch-3850s#sh run all | i password re
Switch-3850s#
5 Replies 5
check which files and directories are in your flash. You might be able to read the content with the sample command below. This from GNS3, the flash is flash0, the directory boot, the subdirectory grub, and the file grubenv
3850#more flash0:/boot/grub/grubenv
There's no any "boot" folder under flash:/
'boot' was just an example. What is the output of 'dir flash" ?
Switch: set
<SNIP>
SWITCH_NUMBER=1
<SNIP>
switch: set
<SNIP>
SWITCH_NUMBER=1
<SNIP>
Switch-3850s#
Matthias
#show romvar
will also do the job without reboot in ROMMON
AIR-LAB1-S1#sh romvar
ROMMON variables:
ASIC_PCI_RESET="1"
AUTO_SWITCH_CONSOLE_DISABLE="0"
BOOT_LOADER_UPGRADE_DISABLE="1"
CFG_MODEL_NUM="WS-C3650-24TS-E"
CLEI_CODE_NUMBER="IPMV810BRE"
CSR_PCIERST_DISCONNECTED="yes"
D_STACK_DOMAIN_NUM="1"
ECI_CODE_NUMBER="470063"
LICENSE_BOOT_LEVEL="ipservicesk9,all:ngwc;"
MAC_ADDR="2C:5A:0F:96:10:00"
MANUAL_BOOT="no"
MODEL_NUM="WS-C3650-24TS"
MODEL_REVISION_NUM="P0"
MOTHERBOARD_ASSEMBLY_NUM="73-15898-06"
MOTHERBOARD_REVISION_NUM="A0"
MOTHERBOARD_SERIAL_NUM="FDO210224Q1"
RECOVERY_BUNDLE="sda9:cat3k_caa-recovery.bin"
SWITCH_IGNORE_STARTUP_CFG="0"
SWITCH_NUMBER="1"
SYSTEM_SERIAL_NUM="FDO2103E0KM"
TAN_NUM="800-41246-03"
TAN_REVISION_NUMBER="B0"
TEMPLATE="advanced"
TERMLINES="0"
VERSION_ID="V04"
BAUD="9600"
ABNORMAL_RESET_COUNT="0"
BOOT="flash:cat3k_caa-universalk9.16.12.01.SPA.bin;"
BSI="0"
RANDOM_NUM="992854735"
AIR-LAB1-S1#
