C3850 MacSec issue
booleung
Frequent Visitor
Frequent Visitor
we've a WS-C3850-24T running software 16.09.06 with ipbasek9 license. When we tried to put the config to the interface we got below,
c3850(config-if)#mka policy mkapolicy1
% GCM-AES-256 is not supported
% Cannot apply MKA Policy "mkapolicy1"...
- Interface is not MACsec capable.
Any ideas why this happened?
Thanks!
Bo
5 Replies 5
Mark Elsen
 - I am not sure it can work with that 'software level' could you have a go with a universak9 image as in :
          https://software.cisco.com/download/home/284455433/type/282046477/release/Gibraltar-16.12.5b
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Thanks for your reply but according to release notes on CCO Macsec MKA was support from 16.9.1
128-bit—(IP Base and IP Services)
256-bit—(IP Services)
Bo
 - I though that the mka policy command was a global configuration setting not per interface , you may try that.
 M.
Yes I know, MKA policy is global under interface looks like this,
macsec network-link
mka pre-shared-key key-chain XXX
 - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv18875
       Check if  the described workaround can be applied to your case too.
 M.
