building catalyst 9300
avdheshkumar
Hi All,
need to replace juniper EX3400 48-port 10/100/1000BASE-T, 4, x 1/10GbE SFP/SFP+, 2 x 40GbE QSFP+
please suggest
On the 9300 usually, you have one slot for uplinks. So, you can use 2, 40Gig, or 8 10Gig but not a combination of both. It is either-or.
5 Replies 5
Reza Sharifi
Not sure what you are asking? Did you already purchase the 9300, or are planning on purchasing them?
If yes, what model?
What do these switches need to connect to? Do you need to uplink these switches via fiber, copper?
Hi Reza,
looking for 48 port 1/10 gig copper with 4x10 gig and 2x40 gig uplinks
can we use combination of uplink modules to achieve this with a 48 port Mgig switch
Hi Reza,
can we use combination of uplink modules to achieve this with a 48 port mGig switch
if the same capacity you can use example
1 X 10G Copper
1 X 10G Fibre
Uplink link module only 1 choice
BB
