dhcp snooping disabled after c9300 17.3.4 upgrade from 16.12.3
patrick.dice
I performed an upgrade to a c9300-48 running 16.12.3 and noticed that the "ip dhcp snoooping" command was not present after an upgrade to 17.3.4.
The "ip dhcp trust" commands are still present.  Anyone else notice this?
hzero
I have C9300s running 17.3.4 that were 16.12 and the command is in the running config.
Yes,  you can simply add the command back in and it works.  17.3.4 is a recommended version to be running on the C9300.  Can't believe this was missed.  I have to think that this was the expected behavour after some other change.
If that is the case then what was the other change?  or was this just missed?
Updated 3 - c9300-48P switches from 16.12.3a to 17.3.4 and all 3 were missing "ip dhcp snoop trust" from the uplink port channel group.  Definately a "new feature".
balaji.bandi
If you add them back and test (is that working ?)
BB
