C3850-NM-2-10G
swelsch
does the C3850-NM-2-10G Module really supports 2 10G Ports and 2 1G Ports at the same time as shown in this table ? I have the 24 Port Switch, so the NM-4-10G is no option.
thanks
As per Cisco documentation - YES.
Catalyst 3850 Switch Hardware Installation Guide
Network Modules
The description of the network module is incorrect. It should read:
C3850-NM-2-10G
Four-slot SFP module:
  • Two slots (left side) support only 1-Gigabit SFP modules and two slots (right side) support either 1-Gigabit SFP or 10-Gigabit SFP modules.
Supported combinations of SFP and SFP+ modules:
  • Slots 1, 2, 3, and 4 populated with 1-Gigabit SFP modules.
  • Slots 1 and 2 populated with 1-Gigabit SFP modules and Slot 3 and 4 populated with 10-Gigabit SFP+ module.
A post in this discussion has been reposted due to possible misconduct. Please refer to the CSC terms of use for more details.
