C3850-NM-4-10G not working
admtkorte
I have two new WS-C3850-24T with C3850-NM-4-10G modules and in both switches they won't work, showing following errors during boot:
"Booting...
Interface GE 0 link down***ERROR: PHY link is down"
" %PLATFORM_PM-6-FRULINK_UNKNOWN_INSERTED: Unsupported FRU module inserted in slot 1"
Currently they are running the suggested release cat3k_caa-universalk9.SPA.03.06.08.E.152-2.E8.bin in INSTALL mode, I have also tried a few older Releases in BUNDLE mode, but the error persists. Any ideas?
#sh inv
NAME: "c38xx Stack", DESCR: "c38xx Stack"
PID: WS-C3850-24T      , VID: V07  , SN: FOC2232U02E
NAME: "Switch 1", DESCR: "WS-C3850-24T-E"
PID: WS-C3850-24T-E    , VID: V07  , SN: FOC2232U02E
NAME: "Switch 1 - Power Supply B", DESCR: "Switch 1 - Power Supply B"
PID: PWR-C1-350WAC     , VID: V02  , SN: LIT22224C3E
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/datasheet_c78-720918.html
"The C3850-NM-4-10G module is supported only on the 48-port Gigabit Ethernet models or on the 12-port or higher 10 Gigabit Ethernet models. The C3850-NM-8x10G and C3850-NM-2x40G modules are supported on the 24-port and 48-port multigigabit switches and also on the 24-port 10G SFP+ switch model. The C3850-NM-4-1G and C3850-NM-2-10G modules are not supported on the 12-port and 24-port SFP+ models."
Search for "Table 2"
Cheers,
Seb.
Seb Rupik
Hi there,
The NM-4-10g does not work in the 24 port models, only the 48 port 3850's.
The NM-2-10g does work.
Let me find the datasheet....
Cheers,
Seb.
Thank you very much Seb,
I simply overlooked that.
