Cisco 3750-X hangs while booting
Abhishek Nanda
 *Mar 1 00:00:07.658: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:05.821: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3750x Next reboot level = ipbase and License = ipbase
*Jan 2 00:01:15.472: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Jan 2 00:01:17.795: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Jan 2 00:01:17.795: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Jan 2 00:01:19.784: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
*Jan 2 00:01:24.875: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jan 2 00:01:32.568: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 1 inserted
*Jan 2 00:01:32.568: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 2 inserted
*Jan 2 00:01:35.470: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan5, changed state to down
*Jan 2 00:01:35.529: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan25, changed state to down
*Jan 2 00:01:35.529: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan26, changed state to down
*Jan 2 00:01:35.529: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan27, changed state to down
*Jan 2 00:01:35.588: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan28, changed state to down
*Jan 2 00:01:35.588: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan101, changed state to down
*Jan 2 00:01:35.663: %SYS-5-CONFIG_I: Configured from memory by console
*Jan 2 00:01:35.865: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Jan 2 00:01:35.865: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Jan 2 00:01:35.865: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Jan 2 00:01:36.393: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
*Jan 2 00:01:37.005: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=1: Transceiver has been inserted
*Jan 2 00:01:37.106: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=2: Transceiver has been inserted
*Jan 2 00:01:37.207: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=3: Transceiver has been inserted
*Jan 2 00:01:37.433: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
*Jan 2 00:01:37.500: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Jan 2 00:01:37.685: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(4)E6, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 05-Apr-18 02:22 by prod_rel_team
*Jan 2 00:01:39.891: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to down
*Jan 2 00:01:40.126: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
*Jan 2 00:01:41.183: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Jan 2 00:01:48.095: %PLATFORM-6-FRULINK_INSERTED: FRULink 10G ST module inserted in Switch 1.
*Jan 2 00:01:48.817: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=17: Transceiver has been inserted
*Jan 2 00:01:49.731: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=16: Transceiver has been inserted
*Jan 2 00:06:03.000: %PHY-5-TRANSCEIVERREMOVED: Slot=1 Port=16: Transceiver has been removed
*Jan 2 00:06:26.874: %PHY-5-TRANSCEIVERREMOVED: Slot=1 Port=17: Transceiver has been removed
*Jan 2 00:07:05.310: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=17: Transceiver has been inserted
*Jan 2 00:07:19.051: %PHY-5-TRANSCEIVERINSERTED: Slot=1 Port=18: Transceiver has been inserted
It doesnt respond further
2 Accepted Solutions
Leo Laohoo
If there are modules attached, remove them and reboot the switch.
Could you try a different IOS? Try the latest 15.0(2)SE train.
You'll need to force the switch to boot into ROMmon and force the switch to boot the IOS using USB.
6 Replies 6
Leo Laohoo
No it still hangs in there.
*Mar 1 00:00:07.650: Read env variable - LICENSE_BOOT_LEVEL =
*Jan 2 00:00:05.872: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3750x Next reboot level = ipbase and License = ipbase
*Jan 2 00:01:15.598: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Jan 2 00:01:17.779: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Jan 2 00:01:17.779: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Jan 2 00:01:19.767: %SMI-5-CLIENT: Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
*Jan 2 00:01:24.850: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jan 2 00:01:32.551: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 1 inserted
*Jan 2 00:01:32.551: %PLATFORM_ENV-6-FRU_PS_OIR: FRU Power Supply 2 inserted
*Jan 2 00:01:35.462: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan5, changed state to down
*Jan 2 00:01:35.462: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan25, changed state to down
*Jan 2 00:01:35.521: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan26, changed state to down
*Jan 2 00:01:35.521: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan27, changed state to down
*Jan 2 00:01:35.529: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan28, changed state to down
*Jan 2 00:01:35.529: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan101, changed state to down
*Jan 2 00:01:35.638: %SYS-5-CONFIG_I: Configured from memory by console
*Jan 2 00:01:35.848: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Jan 2 00:01:35.848: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Jan 2 00:01:35.848: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
*Jan 2 00:01:36.385: %STACKMGR-5-MASTER_READY: Master Switch 1 is READY
*Jan 2 00:01:37.358: %SYS-5-RESTART: System restarted --
*Jan 2 00:01:37.475: %LINK-5-CHANGED: Interface Vlan1, changed state to administratively down
*Jan 2 00:01:39.354: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to down
*Jan 2 00:01:40.210: %USB_CONSOLE-6-MEDIA_RJ45: Console media-type is RJ45.
*Jan 2 00:01:40.361: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
I have already upgraded it to latest ios: Version 15.2(4)E6, RELEASE SOFTWARE (fc4)
Try a different version. The latest 15.0(2)SE is a good one to use.
Hi Leo
Your solution worked. But I dont want it to happen each time the switch reboots. Again after installing the modules the same issue persists. Please suggest a permanent solution to this problem.
