C4500-x not supporting GLC-T SFP
Chala
My cisco C4500-x switch is not supporting GLC-T SFP transciever. the iOS version of the switch is (cat4500e -UNIVERSALK9-M), Version 03.08.01.E. I check the compatablity of the SFP with the switch and found out the iOS version is too old to support the SFP.
Is it really the ios version problem? if yes, how do I upgrade it ?
43 Replies 43
what shall I do then.
Please advice!
@Chala
do
boot system flash bootflash:/<YOU-FILE-NAME-WITH-EXTENSION>
Best regards
then what is next
could you please share me the commands follow up
@Chala
(config)#no boot system
(config)#boot system flash bootflash:/cat4500e-universalk9.SPA.03.08.01.E.152-4.E1.bin
(config)#exit
#wr
Best regards
The highlighted part should be the new ios file name. right ?
yes sir!
Considering that new IOS is on your bootflash...
Best regards
Successfully upgraded the iOS but still the SFP is not working.
@Chala
Consider also upgrading the ROMmon.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_24829.html#pgfId-178803
Check the datasheet about known issues attached to that version (IOS + ROMmon)
Best regards
I have a Cisco 4500X, and it has an IOS image (cat4500e-universalk9.SPA.03.08.01.E.152-4.E1.bin). I tried to upgrade to the latest version with the K9 feature, but the upgrade process failed. Then, I tried upgrading the iOS (cat4500e-universal.SPA.03.11.11.E.152-7. E11) without the K9 feature, and this upgrade process finished successfully. But I couldn't use such as SSH, Encryption Key, and VPN. Finally, I attempted to revert to the previous image because I want to use the K9 feature, but the upgrading process (Downgrade to previous one) is failed. I couldn't back to the previous image. Can you help please.
Why did it fail?  Is it because the BIN file is corrupt?
Why not download 3.11.11 with K9?
Hello @yohannesr
-- What is the error encountered?
Best regards
@Chala
Clean up your bootvariable
Take care  boot field is 0x0, mean: boot the operating system manually with the boot command.
Best regards
Could you share me the steps and commands to change the Configuration register is 0x0 to 0x2102.
Thanks for your support
@Chala
Switch(config)# config-register 0x2102
Switch(config)# end
Switch# wr
Switch# reload
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/25ew/configuration/guide/conf/supcfg.html
Best regards
