NEED IMMEDIATE HELP with RPS2300
craig.rozewski
i have 3 2960-x that io need to migrate off of power before a UPS replacement at my facility. i got a RPS 2300 to try and get power to the switches. i have a 22 to 14 pin cable, but the 2960 and the RPS have 22 pin connectors. i can not find any supporting docs anywhere that fully explain either in detail. can you use the 14 pin, or does it have to be the 22?
craig.rozewski
appreciate what you could help with. thanks
@craig.rozewski
Do you mean this?  As your switch is 2960, you should go with 22-pin cable.
A 22-pin connector on the RPS end, and two varieties of connectors on the switch end:
    22-pin connector for Cisco Catalyst 3750E/3560E, 3750v2/3560v2, 2960/2960S/2960P/2960X Series Switches and 2911/2921/2951 routers (CAB-RPS2300-E=)
    14-pin connector for all other Cisco networking devices (CAB-RPS2300=)
https://www.cisco.com/c/en/us/products/collateral/switches/redundant-power-system-2300/product_data_sheet0900aecd805bbef6.html
all the documents i found only said the 22 pin was for the 37 series. so thank you for that. you wouldnt happen to know by any chance where i can find one in the Niagara Falls area within a day at most. knowing the answer to that before you reply
LOL..Wish I could help with that also.
craig.rozewski
