C4500E SSH problem
Steveosh72
Level 4
Level 4
Running into a proble, we just purchased some 4500E switches with 2 supervisors.
I can not get SSh working to allow connection so we can SSH in to do programming.
i have given it an
IP address..
assigned the domain
aaa new model
crypto key generate rsa
added vtp  (it gets all the correct vlan info )
program the vty lines.
but it times out when trying to connect.
is there something special that i have to do for the 4500e ????
i figured it out.
aaa new-model
aaa group server radius RADIUS_AUTH
server 172.20.253.222 auth-port 1812 acct-port 1813
aaa authentication login networkaccess group radius local enable
aaa authorization exec default group RADIUS_AUTH local if-authenticated
aaa authorization exec RADIUS_AUTH local if-authenticated
radius server RADIUS_AUTH
key 7 7DXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX5C
12 Replies 12
Reza Sharifi
Can you post the output of "sh ver"
In order to use SSH, you need an IOS with "k9" in the ios name.
example:
CAT3K_CAA-UNIVERSALK9-M
thank you. i will look into upgrading
darn.. so here is the boot image
System image file is "bootflash:cat4500es8-universalk9.SPA.03.06.03.E.152-2.E3.bin"
but i can NOT get it to allow to remote in using SSH.
any thoughts?
please post output of -- show ip ssh
and confirm there is no acl on the VTY port when testing remote connection and also confirm the VTY port has transport input ssh under it
Sorry i am new to this model number
sh ssh
%No SSHv2 server connections running.
%No SSHv1 server connections running.
so here is the VTY
line vty 0 4
access-class 99 in
exec-timeout 0 0
password 7 071B24404D080D
login authentication networkaccess
length 0
transport input ssh
line vty 5 10
access-class 99 in
exec-timeout 0 0
length 0
transport input ssh
line vty 11 15
access-class 99 in
exec-timeout 0 0
length 0
since this is a new piece of equipmwent, i do not want it to manage all SSH to the switches that are currently on site.
I just want to be able to connect to this 4500 so my boss  can start to program it
hi so the command needed is --- show IP ssh
And the PC your trying to SSH from , is it allowed in this ACL 99 ?
---access-class 99 in
if not you wont be able to SSH to the switch , you can remove it temporarily to check but put it back on after ----
line vty 0 15
no access-class 99 in
hi there
yes i see in the access list 99 the ip address of my laptop thats trying to connect...
but i did remove it from  line vtp 0 15  and still no luck.
i gave it a host name
so i gave it an IP address (vlan 1)
ip domain-name
I added it to vtp (got all vlans and info)
i ran crypto key generate rsa
am i missing something
anyone HELP please 🙂
i figured it out.
aaa new-model
doesn't sound like your missing anything but need to see the output of the command show ip ssh to at least confirm its working right on the switch and the key is set correctly
are you seeing anything in logs regarding you trying to connect to the switch by ssh ? make sure your local pc firewall software is off too that can block outgoing ssh connections too
