C4948 - configure management IP?
SchinkelA
The subject doesn't explain the whole situation,
I am bridging three locations in my building using pairs of 1GB ports on C4948 switches.
In this case, I have two 'all vlan' trunks on port 1 and 2 from Switch A to Switch B.
Switch A is already configured with a management IP.
I need to configure Switch B with a management IP, preferably it is something that can be configured on port 1 or 2 without interfering with the two 1GB trunks already configured.
Is this possible, and if so, how?
Thank you.
Giuseppe Larosa
Hello ShinkeIA,
usually you can configure an SVI L3 interface that is associated to a specific Vlan-id for example
interface vlan 100
description management
ip address 10.101.100.22 255.255.255.0
the question with C4948 is that it may have a built VRF for management to separate management from user traffic
you can also have a routed interface to be used as out of band management
in this case
you use
interface gix/y
no switchport
ip address 10.101.200.23 255.255.255.0
in both cases if the interfaces need to be part of vrf management you need to configure
ip vrf forwarding mgmt
retype ip address command
where mgmt is a name for the VRF
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/54sg/configuration/guide/supcfg.html#wp1020891
Hope to help
Giuseppe
