trunking to ESX 4.1
w951duu
     I'm trying to turn up trunk ports to an ESX4.1 server, and must be missing something, because I can only ping from ESX setup menu when I have the switchports setup as an access-port.
config is as follows when configured for trunking and it's not working:
interface GigabitEthernet5/13
description server A
switchport trunk allowed vlan 2,3
switchport mode trunk
switchport nonegotiate
speed 1000
duplex full
spanning-tree portfast
end
But if I configure it as an access port in vlan 3 I can ping from the esx to the gateway just fine.
Does ESX require something else for trunking to work?
Giuseppe Larosa
Hello Gregory,
you may be facing a native vlan mismatch:
on cisco side native vlan is 1 (default) ensure that when you configure the ESX for trunking is not considering vlan 3 as the native untagged vlan
Hope to help
Giuseppe
