%C4K_CHASSIS-3-MIXINPOWERDETECTED: Power supplies in the chassis are of dif
tanu
Hi All,
We have a couple of 4500 series switches.
The switches have identical power supplies.
But we still get the following errors.
Check in the error message decoder but that suggestes to have matching power supplies. But if we look at the output of commands we can see that the power supplies are identical.
Swicth#show environment status powersupply
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-4200ACV AC 4200W good good good
PS1-1 220V good
PS1-2 220V good
PS2 PWR-C45-4200ACV AC 4200W good good good
PS2-1 220V good
PS2-2 220V good
Searched for related BUGS but could not find any....
%C4K_CHASSIS-3-MIXINVOLTAGEDETECTED: Power supplies in the chassis are receiving different voltage inputs
%C4K_CHASSIS-3-MIXINPOWERDETECTED: Power supplies in the chassis are of different types (AC/DC) or wattage
The IOS version we are using is 12.2(37)SG1. HAs any one come across this kind of an issue before?
Please reply..
mchin345
Level 6
Level 6
Explanation All the inputs to a chassis must be at the same voltage. Mixed voltage inputs are not supported.
Recommended Action Change the power supplied to the switch so that all inputs to the chassis are of the same type
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/25ewa/system/message/emsg.html
