Cisco SDM
dflores83
Level 2
Level 2
Posted by: dflores83 - Nexit - Mar 10, 2008, 5:10pm PST
Hi.
I have a 2800 router with IOS Version 12.4(9), when I try log in my router with SDM i complicates Sign do it,( I need to put my password 3 times)
when I login in the SDM, the application doesn't allow me to make any changes in my router
Justin Brenton
Level 9
Level 9
Hi dflores83 ,
Have you set the username with a privilege 15?
(config)#username USERNAME privilege 15
Config for SDM
ip http secure-server
ip http authentication local
Please rate the reply.
Justin
Thanks Justin
There was a problem, Now, the SDM works in very well.
Great. I'm glad to see this helped.
Justin
