C6500 + VRF-aware SLB
Bela Mareczky
Hi All!
I am trying to deploy some SLB-based services in multi-VRF environment.
There is no any VRF-related configuration parameters, and there is no any VRF-awareness mentions.
Does anyone have any other information concerning SLB functionality inside VRF?
Device details:
- Catalyst 6509-E
- Modular IOS 12.2(18)SXF14
- SUP720-MSFC3
- FWSM v4.0.6
Thanks in advance!
Belabacsi
Laurent Aubert
It's supported since 12.2(18)SXF. Here is a configuration example:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122limit/122sx/122sxf18/slbsxf5.htm#wp4018895
Basicaly, there is no special configuration on SLB side. The virtual server and its associated server farm interfaces must be in the same Virtual Private Network (VPN) routing and forwarding (VRF).
Laurent.
Hi Laurent!
Thanks for Your reply and the doc link. I wonder if it can work with a VLAN interface routed by an FWSM. What do You think?
BR
Belabacsi
Bela Mareczky
Hi All!
Update:
The per-VRF SLB seems to be OK, but I have a problem with TCP probes.
I have defined two TCP probes, one for each real servers. However, when one of the real servers fails, the TCP probe marks both of them as FAILED. I defined TCP probes as routed, because without "routed" keyword, the TCP probe was unable to reach real servers. (I think, because of the VRF... ?)
Please refer to the configuration below:
ip slb probe TCP_PROBE_1 tcp
address 172.24.250.1 routed
port 80
interval 11
ip slb probe TCP_PROBE_2 tcp
address 172.24.250.2 routed
port 80
interval 11
ip slb serverfarm HCLNET_HOMOKOZO
nat server
predictor leastconns
probe TCP_PROBE_1
probe TCP_PROBE_2
real 172.24.250.1
reassign 2
faildetect numconns 1 numclients 1
retry 20
inservice
real 172.24.250.2
reassign 2
retry 20
inservice
ip slb replicate slave rate 300
ip slb vserver HCLNET_HOMOKOZO
virtual 172.24.250.10 tcp 0
sticky 30 group 1
replicate interval 20
replicate slave
inservice
Any idea?
Thanks and BR
Belabacsi
