07-26-2021 08:14 AM
We are discarding cat6509 e sup 720 10ge. want to make sure no config or info is left behind. let me know what should i do.
Solved! Go to Solution.
07-26-2021 08:55 AM
rkbcontrol,
In addition to what Reza suggested, you can also format the NVRAM and flash after write erase.
Also remember that there are two processors for Sup720, so make sure to erase both the SP and RP memory areas.
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking and Cloud Group
07-26-2021 04:08 PM
Sup720 stores the VLAN database in the "const_nvram:" so make sure to clean those up.
Remove the supervisor card from the slot. Remove the CF cards and the memory modules. Done.
07-26-2021 08:33 AM - edited 07-26-2021 08:33 AM
Just do a "write erase", to delete the config before discarding it.
07-26-2021 08:54 AM
Remove alll the active connection to device before you decomm, Turn off make sure all working network.
Connect the console cable, turn on the device, issue write erage and reload.
07-26-2021 08:55 AM
rkbcontrol,
Cheers,
Scott Hodgdon
07-26-2021 04:08 PM
