C6509e Power Usage
car1o
Visitor
We are buying some C6509Es with Sup2Ts and 8 port 10G cards.  Would like to get a close estimate of the power consumption for our configured chassis. Does anyone have a C6509E with at least the following components that can share their show power output.
Catalyst 6500 Enhanced 9-slot chassis 14RU no PS no Fan Tray1
Catalyst 6509-E Chassis Fan Tray1
Catalyst 6500 24-port GigE Mod: fabric-enabled with DFC41
C6K 8 port 10 Gigabit Ethernet module with DFC4 (Trustsec)1
Catalyst 6500 Dist Fwd Card DFC41
6908 10G baseboard1
Cat6500 6000W AC Power Supply2
Cat 6500 Sup 2T with 2 x 10GbE and 3 x 1GbE with MSFC5 PFC42
Internal 1G Compact Flash2
Cat 6k 80G Sys Daughter Board Sup2T PFC42
Catalyst 6500 Supervisor Engine 2T Baseboard2
Catalyst 6500 2GB memory for Sup2T and Sup2TXL2
It would be greatly appreciated.
Carlo
Reza Sharifi
To get the most accurate numbers for your device use the Cisco Power calculator.  It will give the power consumption per blade and also per sup with different types of power supplies.
http://tools.cisco.com/cpc/
Reza Sharifi
That did the trick.  Though I wonder if the show power command uses the same algorithym as the above link.  I used one of our running C6506's to compare the accuracy between the web page and an actual switch.  The two matched exactly. Shouldn't there be some variance between actual an calculated?
#show power
system power redundancy mode = redundant
system power total =     2331.00 Watts (55.50 Amps @ 42V)
system power used =      1493.94 Watts (35.57 Amps @ 42V)
system power available =  837.06 Watts (19.93 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-2500W       2331.00 55.50  OK     OK     on
2    WS-CAC-2500W       2331.00 55.50  OK     OK     on
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6816-GBIC       269.22  6.41   269.22  6.41  on    on
2    WS-X6816-GBIC       269.22  6.41   269.22  6.41  on    on
3    WS-X6748-GE-TX      325.50  7.75   325.50  7.75  on    on
5    WS-SUP720-BASE      315.00  7.50   315.00  7.50  on    on
6    WS-SUP720-BASE      315.00  7.50   315.00  7.50  on    on
Hub1-C&IT#
#show power
Power Consumption/Heat Disipation Summary/Configuration Details
SlotLine CardOutput
Current(@42V) (A)
Output
Power (W)
Typical Power Used (W)Heat
Dissipation
(BTU/Hr)
Optional
DFC
Power over
Ethernet
Capabilities
FAN2WS-C6K-6SLOT-FAN20.000.000.00359.00
1WS-X6816-GBIC6.41269.22215.381081.63WS-F6K-DFC3A---
2WS-X6816-GBIC6.41269.22215.381081.63WS-F6K-DFC3A---
3WS-X6748-GE-TX7.75325.50260.401307.74-----
4Empty0000----
5WS-SUP7207.50315.00252.001265.56----
6WS-SUP7207.50315.00252.001265.56----
Total35.571493.941195.156361.12
Total Output Current(@42V)35.57 Amps
Total Output Power1493.94 Watts
Total Typical Output Power1195.15 Watts
Total Heat Dissipation6361.12 BTU/Hr
