C6840 Crash
mustafa83
installed the switch few days ago in stand alone setup with 11 6880ia, switch reloaded few minutes ago,
show ver
Cisco IOS Software, c6848x Software (c6848x-ADVENTERPRISEK9-M), Version 15.2(2)SY2, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 11-Jul-16 16:37 by prod_rel_team
ROM: System Bootstrap, Version 15.2(02)SY [Rel 1.0], RELEASE SOFTWARE
HMTWH-C6840-CATV uptime is 44 minutes
Uptime for this control processor is 45 minutes
System returned to ROM by bus error at PC 0x100008, address 0x100008 at 10:34:53 cdt Thu Jul 13 2017
System restarted at 14:57:47 cdt Mon Jul 17 2017
System image file is "bootdisk:/c6848x-adventerprisek9-mz.SPA.152-2.SY2.bin"
Last reload reason: bus error at PC 0x100008, address 0x100008
while we are using Cisco suggested code(at the time of the post)
searched the bugs tool and didnt find any related bug, switch not covered by smartnet so didnt contact TAC yet nor our Cisco Rep.,
will try to upgrade the code to a newer release,
anyone had the same expereince? appreicate the feedback.
Mustafa
Leo Laohoo
Can you post the complete output to the command "dir".
Hello Leo,
Attached dir output showing the carsh file also include the crash file content,
14:57:16 cdt Mon Jul 17 2017: General Protection Fault Exception:   : vector D, PC = 0x5F5F331
Thanks for the file.  It's helpful.
I have found three Cisco Bug IDs:  CSCvc69872, CSCvc34329 & CSCva07166
Here are your options:
  1. Raise a TAC Case to accurately determine what caused the crash (and verify if either one of the three is the correct Bug ID or someone new); and/or
  2. Upgrade the IOS
Do note that Cisco has announced that the EoS for the 15.2(2)SY and the recommended upgrade path is 15.4(1)SY train.  However, I am currently testing 15.4(1)SY1 & 15.4(1)SY2 in several 6840 models and all of them have elevated CPU or higher-than-normal due to "slcp process".  I have an existing TAC case.
Thanks for your helpful feedback, we upgraded the code to 15.2.(2) SY3.
