%C6KPWR-SW2_STBY-4-DISABLED: power to module in slot 2 set off (FRU-power failed)
abhisar patil
Dear Team,
One of the module on switch 2 in VSS is not powered on. I am getting following logs. What can be the issue? I have rebooted the switch 2 but still the same. Shall I remove the card and insert again?
%OIR-SW1-6-INSREM: Switch 2 Physical Slot 1 - Module Type LINE_CARD  inserted
Nov 27 10:46:14.400: %OIR-SW2_STBY-6-PWRFAILURE: Module 2 is being disabled due to power convertor failure. PMB registers are dumped as follows,  R0= 0x8, R1= 0x3, R2= 0x3, R3= 0x0, R4= 0x0, R5= 0x7, R6= 0x0, R7= 0x0, R8= 0xF, R9= 0xF, R10= 0xD, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x2, R15= 0x0
Nov 27 10:46:14.620: %C6KPWR-SW2_STBY-4-DISABLED: power to module in slot 2 set off (FRU-power failed)
Nov 27 10:46:14.620: %SYS-SW2_STBY-3-LOGGER_FLUSHED: System was paused for 00:00:11 to ensure console debugging output.
Nov 27 10:46:17.368: %OIR-SW1-6-INSREM: Switch 2 Physical Slot 2 - Module Type LINE_CARD  inserted
Nov 27 10:46:17.372: %OIR-SW1-6-INSREM: Switch 2 Physical Slot 5 - Module Type LINE_CARD  inserted
Nov 27 10:46:30.940: %OIR-SW2_STBY-6-PWRFAILURE: Module 2 is being disabled due to power convertor failure. PMB registers are dumped as follows,  R0= 0x8, R1= 0x3, R2= 0x3, R3= 0x0, R4= 0x0, R5= 0x7, R6= 0x0, R7= 0x0, R8= 0xF, R9= 0xF, R10= 0xD, R11= 0x0, R12= 0x0, R13= 0x0, R14= 0x2, R15= 0x0
Nov 27 10:46:31.160: %C6KPWR-SW2_STBY-4-DISABLED: power to module in slot 2 set off (FRU-power failed)
Nov 27 10:46:32.984: %OIR-SW1-6-INSREM: Switch 2 Physical Slot 2 - Module Type LINE_CARD  removed
Nov 27 10:46:33.968: %OIR-SW1-6-INSREM: Switch 2 Physical Slot 2 - Module Type LINE_CARD  inserted
Please help.
Thank You,
Abhisar.
Hi Abhisar,
From the logs message, it looks like a power converter failure on the module, mostly its a hardware issue .  but you can try reseat the module once (remove and insert it back).
If its not came up then you have to replace the module.
VS.Suresh.
*Plz rate the usefull posts *
Dear Suresh,
Thank you for the comment. I am planning for removing and inserting the module. I will let you know the status after that.
Thank You,
Abhisar
Hi Abhisar,
Sure. Thanks
