C9200-24T-E with C9200-NM-4X configuration question
KristianS
I have to pre-configure a C9200-24T-E. It will have C9200-NM-4X installed in it.
I am not sure which SFP modules will be used 1Gig or 10 Gig.
Can I configure interface GigabitEthernet1/1/1and interface TenGigabitEthernet1/1/1 with same configuration to cover either option?
you can use 10G or 1G SFPs in that module. when configuring, there should be TenGigabitEthernetx/x/x interfaces for both speeds. no sperate interfaces for each speeds.
Good luck
KB
Checking another site with C9200-24T-E with C9200-NM-4X. I can see interface GigabitEthernet1/1/1-GigabitEthernet1/1/4 and interface TenGigabitEthernet1/1/1-interface TenGigabitEthernet1/1/4 present. Copper 1 gig ports are GigabitEthernet1/0/1-GigabitEthernet1/0/24.
So what are the GigabitEthernet1/1/1-GigabitEthernet1/1/4?
