C9200 Auto QOS dropping packets Drop-TH1
the-lebowski
Level 4
Level 4
Recently deployed 'auto qos trust dscp' on our LAN.
On one of our access point facing 9200s I am seeing a fair amount of drops on pretty much every interface connected to a Meraki AP.   Drops I wasn't seeing before we implemented QOS.   I know QOS is working because I can see the packets matching the queues and being prioritized on the edge (PAN firewall) but I am not clear on what is going on at the port level and whether I should be concerned or not.
We are tagging traffic in ZOOM and matching those tags in Meraki via traffic shaping rules so that we can tag end to end and it appears to be working as intended.  But how do I find out what is being dropped and why?
show int gi1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 9077.ee6f.4881 (bia 9077.ee6f.4881)
  Description: Meraki AP-12
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is on, output flow-control is unsupported
  Last input 00:00:04, output 00:00:00, output hang never
  Last clearing of "show interface" counters 1d03h
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 11475
  Queueing strategy: Class-based queueing
  Output queue: 0/40 (size/max)
  5 minute input rate 1783000 bits/sec, 534 packets/sec
  5 minute output rate 5836000 bits/sec, 988 packets/sec
     12458330 packets input, 7531546540 bytes, 0 no buffer
     Received 68153 broadcasts (62589 multicasts)
     0 watchdog, 62589 multicast, 0 pause input
     25437782 packets output, 18232537449 bytes, 0 underruns
     Output 111605 broadcasts (0 multicasts)
     3326 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
9200#show policy-map int gi1/0/1
  Service-policy input: AutoQos-4.0-Trust-Dscp-Input-Policy
    Class-map: class-default (match-any)
      179649055 packets
      Match: any
      QoS Set
         dscp dscp table AutoQos-4.0-Trust-Dscp-Table
  Service-policy output: AutoQos-4.0-Output-Policy
    queue stats for all priority classes:
      Queueing
      priority level 1
      (total drops) 11475
      (pkts output) 1348718
    Class-map: AutoQos-4.0-Output-Priority-Queue (match-any)
      0 packets
      Match:  dscp cs4 (32) cs5 (40) ef (46)
      Match: cos  5
      Priority: 30% (300000 kbps), burst bytes 7500000,
      Priority Level: 1
    Class-map: AutoQos-4.0-Output-Control-Mgmt-Queue (match-any)
      0 packets
      Match:  dscp cs2 (16) cs3 (24) cs6 (48) cs7 (56)
      Match: cos  3
      Queueing
      queue-limit dscp 16 percent 80
      queue-limit dscp 24 percent 90
      queue-limit dscp 48 percent 100
      queue-limit dscp 56 percent 100
      (total drops) 0
      (pkts output) 806829
      bandwidth remaining 10%
      queue-buffers ratio 10
    Class-map: AutoQos-4.0-Output-Multimedia-Conf-Queue (match-any)
      0 packets
      Match:  dscp af41 (34) af42 (36) af43 (38)
      Match: cos  4
      Queueing
      (total drops) 0
      (pkts output) 84
    Class-map: AutoQos-4.0-Output-Trans-Data-Queue (match-any)
      0 packets
      Match:  dscp af21 (18) af22 (20) af23 (22)
      Match: cos  2
      Queueing
      (total drops) 0
      (pkts output) 839
    Class-map: AutoQos-4.0-Output-Bulk-Data-Queue (match-any)
      0 packets
      Match:  dscp af11 (10) af12 (12) af13 (14)
      Match: cos  1
      Queueing
      (total drops) 0
      (pkts output) 215821
      bandwidth remaining 4%
    Class-map: AutoQos-4.0-Output-Scavenger-Queue (match-any)
      0 packets
      Match:  dscp cs1 (8)
      Queueing
      (total drops) 0
      (pkts output) 12475377
      bandwidth remaining 1%
    Class-map: AutoQos-4.0-Output-Multimedia-Strm-Queue (match-any)
      0 packets
      Match:  dscp af31 (26) af32 (28) af33 (30)
      Queueing
      (total drops) 0
      (pkts output) 9
      0 packets
      Match: any
      Queueing
      (total drops) 0
      (pkts output) 10595787
      bandwidth remaining 25%
9200#show plat hardware fed switch active qos queue stats interface gi1/0/1
AQM Global counters
GlobalHardLimit:  3781   |   GlobalHardBufCount: 0
GlobalSoftLimit:  9531   |   GlobalSoftBufCount: 0
Asic:0 Core:0  Port:4 Hardware Enqueue Counters
 Q Buffers          Enqueue-TH0          Enqueue-TH1          Enqueue-TH2             Qpolicer
   (Count)             (Frames)             (Frames)             (Frames)             (Frames)
 0       0                    0              1091859               405618                    0
 1       0                 2334               108712               743377                    0
 2       0                    0                    0                  116                    0
 3       0                    0                    0                  842                    0
 4       0                    0                    0               218652                    0
 5       0                    0                    0             13950087                    0
 6       0                    0                    0                    9                    0
 7       0                    0                    0             11425586                    0
Asic:0 Core:0  Port:4 Hardware Drop Counters
 Q             Drop-TH0             Drop-TH1             Drop-TH2             SBufDrop              QebDrop         QpolicerDrop
               (Frames)             (Frames)             (Frames)             (Frames)             (Frames)             (Frames)
 0                    0                11488                    0                    0                    0                    0
 1                    0                    0                    0                    0                    0                    0
 2                    0                    0                    0                    0                    0                    0
 3                    0                    0                    0                    0                    0                    0
 4                    0                    0                    0                    0                    0                    0
 5                    0                    0                    0                    0                    0                    0
 6                    0                    0                    0                    0                    0                    0
 7                    0                    0                    0                    0                    0                    0
0 Replies 0
