06-27-2024 09:59 AM
Hi there,
Thanks for reading!
I ran a capture on a C9200 with these parameters and only captured one-way traffic. I was trying to see if the server at the destination IP was responding and thought that 3rd line Direction: Both would reveal the traffic stream from both ends. The capture only showed one-way traffic from the client at the source IP. Here's the mon cap settings. Did I prank myself?
06-27-2024 10:28 AM
9300_54#monitor capture CAP interface x/x/x in
9300_54#monitor capture CAP match host <server>
9300_54#monitor capture CAP start
9300_54#monitor capture CAP stop
9300_54#monitor capture CAP export location flash:cl.pcap
9300_54#sh monitor capture file flash:cl.pcap
try this way
MHM
06-27-2024 01:02 PM
Example from official guide always works for me. (check the time you like to capture, more you leave it fill up flash and switch may not have enough space) chances are crashing the router. so setup the time how long you want to capture.
#monitor capture CL interface GigabitEthernet 1/0/2 both
#monitor capture CL match ipv4 any any
#monitor capture CL limit duration 60
#monitor capture CL file location flash:cl.cap
#monitor capture CL start display brief
#show monitor capture file flash:cl.cap brief
#show moni capture file flash:cl.cap packet-number 1 detailed | be Transmission
=====️ Preenayamo Vasudevam ️=====
06-27-2024 04:13 PM
Try to apply it to a physical port as Embedded Packet Capture (EPC) isn't supported on logical ports, which includes port channels, switch virtual interfaces (SVIs), and subinterfaces. It's supported only on physical ports.
