C9200 Switch Stack - Remote command
systemadmin55
I'm currently setting up a pair of C9200-24T switches in a stack. I'm running the show version command and I only see the switch uptime of Switch 02. I don't see the uptime of Switch 01. I also have a stack of C2960x's that does the same thing. However, on the 2960 I can run "remote command 1 show version" and it returns the uptime of switch 01. The remote command does not work in the C9200s.
When I run re? I get: redundancy, release, reload, rename, renew, rep, request, restart and resume. No remote? Appears this command has been removed. How do you check the uptime of individual switches in a switch stack then? I had an issue in the past where one switch in a stack was rebooting and I needed to see that uptime so this command was useful.
I'm running:
Cisco IOS Software [Amsterdam], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 17.1.1, RELEASE SOFTWARE (fc3)
systemadmin55
Looks like show redundancy in this version gives me the output I'm looking for.
systemadmin55
