Catalyst 3560 set Baudrate
I have a 3560 switch which Baudrate has been set in the xmodem prompt to 57600 to speed up the image upload.
How can be the baudrate set back to the default 9600?
Thank you so much.
balaji.bandi
i belive that baudrate for only xmodem, once you done upload, it should come back to 9600 as per i remmeber.
config t
line console 0
speed 9600
end
wr
reload  < -- switch will reload here
here is the guide if you like to change :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-4000-series-switches/21229-pswdrec-cat4000-supiii-21229.html
BB
balaji.bandi
config t
line console 0
speed 9600
end
wr
BB
Thank you!
This worked:
config t
line console 0
speed 9600
end
wr
