C9200L stacking
We are planning to order C9200L-24T-4G-A switch as replacement of C2960S-24TS-L-V04, is that a correct replacement?
Also please advise what is the model of stacking kit and stacking cable suitable for C9200L-24T-4G-A
M02@rt37
Hello @santhoshbaskaran
2960S-24TS-L was replace by 2960X series. 2960X series replace by C9200 series.
Check C9200 datasheet to find the equivalent model of your 2960S in terms of ports, uplinks etc.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.htm
Also, Table 5. of the datasheet show you the Stack Kit model for C9200L.
C9200L-24T-4G seem to be good. You should more elaborate if you need further info and advices.
Best regards
Leo Laohoo
Without knowing anything about the network, I am not going to answer this question.
@santhoshbaskaran hi, as @Leo Laohoo mentioned, we need more details about your network such as switch placement (distribution/access), VLAN expectations, throughput expectations etc. because if you need lower throughput, you can select switch from C1000 series also.
for your second question, you need to use C9200L-STACK-KIT for 9200L series as a stack module.
Good luck
KB
M02@rt37
Best regards
