C9200 configure problem
w11dgod
Dear all I'm having a trouble while I was configuring my switch
So I wanted to add up this line to my switch
statistics packet protocol
but it kept pointing out that the statistics command had an error like below
(config-flow-monitor)#statistics packet protocol
% Invalid input detected at '^' marker.
version:17.06.05
model:cisco catalyst 9200 48p
@w11dgod hi it seems like this is not supported in 9200 switches.
Command Reference, Cisco IOS XE Bengaluru 17.6.x (Catalyst 9200 Switches) - Index [Cisco Catalyst 9200 Series Switches] - Cisco
you are checking ASR router config guide.
Good luck
KB
@w11dgod hi can you share the available command list in (config-flow-monitor)# prompt? using '?'
Good luck
KB
Hi I did use "?" to see if there's a statistic command but there's nothing about it, but the document below said that this command supports 17.X version
https://www.cisco.com/c/en/us/td/docs/routers/ios/config/17-x/ntw-servs/b-network-services/m_fnf-egress-vrf.html
here's the result of after entering ? in config-flow-monitor
(config-flow-monitor)#?
accessTunnel Filter traffic from access tunnel
cache Configure Flow Cache parameters
default Set a command to its defaults
description Provide a description for this Flow Monitor
exit Exit from Flow Monitor configuration mode
exporter Add an Exporter to use to export records
no Negate a command or set its defaults
record Specify Flow Record to use to define Cache
skipouter Skip the outer header information
Good luck
KB
Oops! Okay... did not notice that lol~
Thanks for the assistance!!!
