C9300 BIN File Missing in Flash after copy
KrisFLIP
I am performing an IOS upgrade.  I was able to copy the BIN file from USBFLASH but when I go to the switch FLASH, the BIN is not there, therefore I am not able to perform IOS upgrade.  Copy to FLASH completed with no errors.  Current version is 16.06.06 upgrading to 16.09.04.  C9300 is in INSTALL mode.  Any help is good.  Thanks!
My guess is correct.
delete the Y file from flash:
delete flash:Y
Once deleted check dir flash: ( you should not see the Y file with lasrge size)
do again copy
copy usbflash0:cat9k_iosxe.16.09.04.SPA.bin flash:
this time Keep Press "Enter" Key  rather press "Y"
Follow @Reza Sharifi  provided guide for upgrade. you should be good.
BB
6 Replies 6
Reza Sharifi
Maybe you copied it in a different area of flash. Try "dir" and that should show you the bin file. Also, see this document for upgrading the IOS in install mode. Start in install mode section:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-9/release_notes/ol-16-9-9300.html#id_77760
Thanks for sharing the link, Reza.
I used the command to copy the files to flash
Switch returned the result below after the copy
705009898 bytes copied in 111.602 secs (6317180 bytes/sec)
When I do a dir flash: or dir I still don't see the BIN file.
When you issue the command below :
it will ask you destination as same file name (most people enter Y here, so the file copy as Y)
Can you post dir flash: (out put here )
BB
Hi Balaji - here is the result
delete flash:Y
do again copy
BB
Hi Balaji
Your guess is right - I'm an idiot!  Thanks for the help!
