C9300 - CoPP - Class map for SSH in system-cpp-policy
Endy00000
Frequent Visitor
Frequent Visitor
I'm not sure why SSH is still being passed to the control plane. We have some automation issues we're trying to work out, but i'm trying to incorporate a temporary solution.
The goal here is to limit the amount of SSH traffic. It appears that SSH traffic is causing the CPU to spike to 80-100% quite frequently even with the following CoPP provisioning in place.
What could i have missed? Why does the policy map not show SSH conformed traffic?
Model: C9300-48U
Version: 17.09.03
## show ip access-lists SSH-ACL
Extended IP access list SSH-ACL
10 permit tcp any any eq 22
20 permit tcp any eq 22 any established
## show class-map SSH-Class
Class Map match-any SSH-Class (id 24)
Match access-group name SSH-ACL
## show policy-map control-plane input
Control Plane
Service-policy input: system-cpp-policy
Class-map: SSH-Class (match-any)
0 packets, 0 bytes
5 minute offered rate 0000 bps, drop rate 0000 bps
Match: access-group name SSH-ACL
police:
rate 500 pps, burst 122 packets
conformed 0 bytes; actions:
transmit
exceeded 0 bytes; actions:
drop
# Here is just a quick snapshot
# show processes cpu sorted | exclude 0.00
CPU utilization for five seconds: 62%/3%; one minute: 26%; five minutes: 15%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
617 8285 9170 903 85.59% 8.79% 2.48% 2 SSH Process
#show processes cpu history
88888333335555599999777774444411111 11111
553333388888444444444477777444446666666666777777777722222555
100
90 *****
80 ***** **********
70 ***** **********
60 ***** **********
50 ***** ***************
40 ******************************
30 ******************************
20 ***********************************
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
9 3 311509 3 1 2599 31 3 3699123 31 919
485597576601103766560836955689075586676781980965690765575899
100 * ** ** *
90 * ** ** ** *
80 * ** ** ** *
70 * ** ** ** *
60 * ** *** *** *
50 * *** *** *** *
40 # * * *#* * *** * * ***# * * *
30 # * * *#* * *## * * **## ** * #
20 # * * ### * **## * * **## ** * #
10 #***#***##*####**#****####**##****#*****####*##**#*******#
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
1 1 1
0999111493191181189811111199111403101191311111111191 11383191 81 1111111
045801047608100009490000119601200510003081111111119090067005096090001001
100 * ** * * ** * * * *
90 **** * * *** ** * * * * * * *
80 **** * * * *** ** * * * * * * *
70 **** * * * *** ** * * * * * * *
60 **** * * * *** ** * * * * * * *
50 **** * * * *** ** * * * * * * *
40 **** *** * * *** ** *** * * * * ** * *
30 **** *** * * *** ** *** * * * * *** * *
20 **** *** * * *** ** *** * * * * *** * *
10 #*##*************##*******##******************************************
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
20 permit tcp any eq 22 any established <<- no need establised this is not direction ACL that need ACL to work from one direction
remove the established and check again
MHM
8 Replies 8
balaji.bandi
what IOS XE Code running ? try to upgrade to 17.3.6 or above.
i used below for testing : i can see SSH traffic hitting the ALC and i can see the effective :
Step 1 : Access list
ip access-list extended SSH
Step 2 : Class Map
class-map match-all CM-SSH
match access-group name SSH
Step 3 : Policy Map
policy-map PM-COPP
class CM-SSH
police 50000 conform-action transmit exceed-action transmit
class class-default
police 12000 conform-action transmit exceed-action transmit
Step 4: Apply the CoPP policy
control-plane
service-policy input PM-COPP
BB
Georg Pauwen
odd. Can you try if the below works ?
class-map match-any SSH_TRAFFIC
match protocol ssh
policy-map SYSTEM-CPP-POLICY
class SSH_TRAFFIC
police 8000 1500 3000 conform-action transmit exceed-action drop
control-plane
service-policy input SYSTEM-CPP-POLICY
Endy00000
Frequent Visitor
Frequent Visitor
Hey Georg,
Yeah, it is a bit odd. I attempted your suggestion.
for some reason, the class map will not associate to the policy map. I'm not sure why.
sorry I see it Now.
MHM
MHM
Endy00000
Frequent Visitor
Frequent Visitor
Its working now!
I may need to fine tune the exceed traffic.
0 packets, 0 bytes
police:
rate 8000 bps, burst 1500 bytes
conformed 86622 bytes; actions:
transmit
exceeded 87238 bytes; actions:
drop
conformed 7000 bps, exceeded 8000 bps
You are welcome
But can I ask something
This SSH is high when you try access SW or when SW use SSH for some service ?
MHM
SSH traffic is caused by DNAC. We dont quite know why DNAC is creating multiple SSH connections and running a sync so much. Could be bug related.
