C9300-NM-4G module
Question regarding the C9300-NM-4G module, can I use this module on a C9200 switch?
Leo Laohoo
No, it will not fit.  The back pins were purposely designed to be different.
6 Replies 6
marce1000
 - No ,  FYI : https://www.router-switch.com/cisco-c9300-nm-4g-datasheet-pdf.html
 >...  Supported Devices   :          Cisco Catalyst 9300 Series
   M.
Correction the module is C9200-NM-4X.
C9200-NM-4X
yes that is compatable with Cat 9200
Look at the datasheet :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html
BB
Sorry guys its that im getting the correction from the customer now, so what they have is C9200 switches, and they need the C9200-NM-4X module but the distributor only has the C9300-NM-4X, but with what merce1000 replied it does not.
yes you confused post, so the answer is NO, it will not work, ask the customer to buy Cat 9300 for the module to work.
BB
Leo Laohoo
