C9300 Power Budget
Christian P
I have a question for the community.
On the C9300 Datasheet, it is said that on a C9300-48P equiped with PWR-C1-715WAC-P, the POE Budget is 437W.
When we check the power (show power inline or show stack-power budget), it isn't clear that we only have "only" 437W available. However it is clearly specified that we have 685W available (minus the 30W for the switch)....
So, questions:
Which number is correct?
What is the real POE budget on a switch?
If the datasheet is correct, what is the command to get the reall power budget? or do we have to export print outs to do the excel math??
balaji.bandi
you get max PoE budget 437W - that is correct (278 around reserverd Switch to Operate - if you load fully populated - you see more information) if the switch just booted nothing connected what you see information correct. (but budget max of 437W)
BB
balaji.bandi
BB
