Cisco 3750-X upgrade problem
athraya
Hi ,
I try to upgrade a C3750-X 24S with tar archive , switch seems hang to "Extracting image from archive into flash....."
here the log :
FiberSW#dir flash:
Directory of flash:/
2 -rwx 796 Mar 5 1993 15:48:56 +00:00 vlan.dat
4 -rwx 18586368 Jan 1 1970 01:01:34 +00:00 c3750e-universalk9-mz.150-1.SE.bin
587 -rwx 1912 Mar 1 1993 00:01:50 +00:00 private-config.text
589 -rwx 3096 Mar 1 1993 00:01:50 +00:00 multiple-fs
588 -rwx 2213 Mar 1 1993 00:01:50 +00:00 config.text
119144448 bytes total (100495360 bytes free)
FiberSW#$ture-upgrade tftp://192.168.1.2/c3750e-universalk9-tar.152-4.E10.tar
Loading c3750e-universalk9-tar.152-4.E10.tar from 192.168.1.2 (via FastEthernet0): !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 30720000 bytes]
examining image...
extracting info (109 bytes)
extracting c3750e-universalk9-mz.152-4.E10/info (540 bytes)
Stacking Version Number: 1.59
System Type: 0x00000002
Ios Image File Size: 0x01860200
Total Image File Size: 0x01D49A00
Minimum Dram required: 0x08000000
Image Suffix: universalk9-152-4.E10
Image Directory: c3750e-universalk9-mz.152-4.E10
Image Name: c3750e-universalk9-mz.152-4.E10.bin
Image Feature: IP|LAYER_3|PLUS|SSH|3DES|MIN_DRAM_MEG=128
FRU Module Version: 03.08.10.WAL
Old image for switch 1: unknown
Extracting images from archive into flash...
I wait long time, without any change. Also I try different image , delete update folder etc.. same thing
Thank 's for help
amikat
Please be aware that it can take around 10 - 15 minutes between "Extracting images from archive into flash..." and the next output message.
Best regards,
Antonin
marce1000
    - Check logs on the switch after trying ,
 M.
amikat
Best regards,
Antonin
