c9300 switch ping command usage
jmcgrady1
I have used the IOS ping command for years. Very useful.  A question though - can it be configured to send one ping per second? I can specify how many pings to send and the timeout, but i cant see where to set a delay between each ping. It sends as fast as it can.
marce1000
 - Ref : https://www.cisco.com/c/en/us/support/docs/ip/routing-information-protocol-rip/13730-ext-ping-trace.html
                 Perhaps delay can be influenced when using the Timeout option.
 M.
Unfortunately not. Timeout just affects how long to wait for a reply. It doesnt affect the rate at which pings are sent
      - You are probably right, I was assuming that timeout might then affect the sending rate too.
 M.
yboukredine
Also from the web dashboard of the appliance via the left menu :
Troubleshooting > Ping and Trace Route
More confortable
--Yoann
