C9300 UPOE +
I have a question regarding UPOE+ and POE, POE+, if I have a C9300 with UPOE+ can are POE or POE+ devices supported?
Yes, UPOE+ is up to 90W and that is also backward compatible.
5 Replies 5
Reza Sharifi
Yes, should work fine. UPOE is up to 60W and POE+ is up to 30W.
UPOE is backward compatible.
Is it the same for UPOE+ ?
Yep...all of them supported
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
It all depends on the device through the CDP or LLDP negociation.
