C9300L-24P-4X-E handle up to 1100 Watt Power supply?
Hello everyone? Just a quick question regarding the new C9300L-24P-4X-E switch I know that it comes default with a  715 Watt Power Supply. Can it handle an 1100 Watt Power supply though? Thanks for any help and suggestions. I really appreciate it!
Appolgies, first i was reading as 48port, then i realise the model is 24, so corrected the right answer.
BB
9 Replies 9
balaji.bandi
@balaji.bandi wrote:
yes it support
Awesome! THank you very much for the quick feedback! I appreciate it!
i gotcha then. I thought you just said in your first posting that it could support 1100 Watt power supply though? Ok, thanks for the info then. I appreciate it.
BB
d
Awesome, thanks again for the fast response! I appreciate it.
marce1000
 - Not recommended it may got fried , reserve for your microwave , seriously device should be used and configured according to specification in the datasheet.
 M.
Leo Laohoo
24-port can support 1100w power supply and will not get "damaged".
Y'all know the reason why?  Power-Stack.
"24-port can support 1100w power supply"
I am puzzled here - may be i am wrong, so lets clarify here -  the model described or original post will that support 1K PSU ? please clarify
BB
3750X, 3650/3850, 9300/9300L 24-port switch can support 1100w power supply and not "burn" the board because of Power Stack.
