C9300S model switch ports
LarryAguon86572
Does the 9300S model switch support 100Mb access connections?
2 Accepted Solutions
Here are all the 1Gig fiber SFP switches. They are all 1Gig only.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
C9300-24S-E
Catalyst 9300 24-port 1G SFP with modular uplinks, Network Essentials
C9300-24S-A
Catalyst 9300 24-port 1G SFP with modular uplinks, Network Advantage
C9300-48S-E
Catalyst 9300 48-port 1G SFP with modular uplinks, Network Essentials
C9300-48S-A
Catalyst 9300 48-port 1G SFP with modular uplinks, Network Advantage
@LarryAguon86572 : Well all these switches has 1 G SFP ports ( 24 Port Switch and 48 Port Switch). I hope you got the answer already. Good Luck !
Inderdeep Singh
www.thenetworkdna.com ( Awarded by Cisco IT Blogs award 2020)
10 Replies 10
inderdeeps
Level 4
Level 4
@LarryAguon86572 :When you are saying access connection, Are you asking for the WAN connection to the service providers ?
Inderdeep Singh
I am talking about access ports on the switch for users/endpoints.  Thanks.
Inderdeep Singh
Thanks inderdeeps.  I was curious why 1G was listed as a minimum, when 100Mb connections are supported.
What, exactly, are the medium the endpoints require?  Copper or fibre optic?
Reza Sharifi
What is the exact part number of the switch?
If you are referring to "c9300-24S" this switch comes with 24 ports of 1Gig fiber SFP.
Yes, this is the model I have.  The data sheet shows 1G SFP in the port scale column, but why would Cisco set a minimum port speed at 1G.  Maybe this switch is incompatible with what we are using it for
C9300-24S-E
C9300-24S-A
C9300-48S-E
C9300-48S-A
Thanks for the quick response.
Glad to help Larry!
Good luck.
