c9300switch
mzedanmzedan
Frequent Visitor
Frequent Visitor
I have two switches "c9300 24p " stacked and I want to connect to a switch via connecting two trunks with two ports from the catalyst 2960G.
The question is: Is this connection make a loop? and if it makes a loop? what's the best practise for connection to benefit the redundancy?
You have to build a port-channel between both devices. All member-interface together will build a logical link without any loop.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
balaji.bandi
what is the reason of 2 Trunks ? as long as only VLANs allowed in the trunk, that not cause any loops
rather as suggested create a Port-channel it got more redundency  also.
BB
