02-05-2020 04:47 AM
Wonder if anybody could help me. My company has just ordered a couple of C93216TC-FX2 switches.
I was wondering if anybody knows the port numbering? The switch comes with 96 100/1/10Gig ports and 12 40/100G ports. I'm just trying to understand the port number used on this switch. will the port be called for example e1/1 - 108 or will the ports be on different modules. Had a look online and there doesn't appear any info on this.
Kind regards,
Terry.
Solved! Go to Solution.
02-05-2020 06:21 AM
02-05-2020 06:41 AM
I think your assumption of numbering is correct. There is not exact data explaining it but according to in this link, it is e1/1-96 and than 97-108 for uplinks.
02-05-2020 06:21 AM
02-06-2020 12:21 AM
02-05-2020 06:41 AM
02-06-2020 12:22 AM
