Cisco Switch 3850 model : SSH Connection Refused, network error.
Tosin Ola
Level 2
Level 2
Hi ,
I have been troubleshooting this switch 3850 about 3 days now but still no luck. The switch cannot connect remotely through SSH.
i did sh ip ssh command:
RESULT
SSH Disabled - version 2.0
%Please create RSA keys to enable SSH (and of atleast 768 bits for SSH v2).
Authentication methods:publickey,keyboard-interactive,password
Authentication Publickey Algorithms:x509v3-ssh-rsa,ssh-rsa
Hostkey Algorithms:x509v3-ssh-rsa,ssh-rsa
Encryption Algorithms:aes256-ctr
MAC Algorithms:hmac-sha1-96
KEX Algorithms:diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1
Authentication timeout: 120 secs; Authentication retries: 3
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): NONE
#sh ssh
%No SSHv2 server connections running.
LINE VTY CONFIG
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 0239532B1E312145
authorization exec AAA
accounting commands 15 AAA
login authentication AAA
transport input ssh
transport output ssh
line vty 5 15
transport input ssh
Please what am i doing wrong.  I really need this switch to work as client are putting more pressure on me.
Tosin Ola
Level 2
Level 2
Below is the commad i used :
no ip ssh rsa keypair-name sshkey
ip ssh server algorithm mac hmac-sha2-512 hmac-sha2-256 hmac-sha1-96 hmac-sha1
ip ssh server algorithm encryption aes256-ctr aes192-ctr aes128-ctr
crypto key generate rsa [Modulus 1024]
sh ip ssh [SSH Enabled v2.0]
5 Replies 5
Mark Malone
hi
you have no key create it cehck again show ip ssh
(config)#crypto key generate rsa
hit return and type 2048 and hit return again
then run show ip ssh again
i have generated crypto key using modulus 768 and 1024 .
I will try and use 2048 bit and see how it goes
If it doesnt work post what you see exactly , in case something else is happening but currently without a Key you wont get an SSH
Jaderson Pessoa
Hello, do it:
sw(config): username teste privilege 15 secret testin@123 (create a batter than this exemple)
sw(config): crypto key generate rsa modulus 2048
sw(config): ssh version 2
sw(config): line vty 0 15
sw(config-if): transport input ssh
test your connection again.
here you will find a good documentation about this process: https://www.cisco.com/c/en/us/support/docs/security-vpn/secure-shell-ssh/4145-ssh.html
Jaderson Pessoa
*** Rate All Helpful Responses ***
Tosin Ola
Level 2
Level 2
