C9500-16X - %FMFP-3-OBJ_DWNLD_TO_DP_STUCK: Switch 1 R0/0: fman_fp_image: AOM download to Data Plane is stuck for more than 1800 seconds for obj[2253953] type[21] pending-issue Req-delete Issued-none 'uRPF-list(hdl=0x500000d6)'
Daniel Marques
Hello Guys,
Since last week my catalyst 9500 start to show the following logs:
001204: Oct 4 00:10:08.930 BST: %FMFP-6-OBJ_DWNLD_TO_DP_RESUME: Switch 1 R0/0: fman_fp_image: AOM download of objects to Data Plane is back to normal
001206: Oct 4 11:40:08.855 BST: %FMFP-3-OBJ_DWNLD_TO_DP_STUCK: Switch 1 R0/0: fman_fp_image: AOM download to Data Plane is stuck for more than 1800 seconds for obj[274354] type[21] pending-issue Req-delete Issued-none 'uRPF-list(hdl=0x5000021b)'
001207: Oct 4 17:10:08.820 BST: %FMFP-6-OBJ_DWNLD_TO_DP_RESUME: Switch 1 R0/0: fman_fp_image: AOM download of objects to Data Plane is back to normal
001208: Oct 4 18:10:08.814 BST: %FMFP-3-OBJ_DWNLD_TO_DP_STUCK: Switch 1 R0/0: fman_fp_image: AOM download to Data Plane is stuck for more than 1800 seconds for obj[274354] type[21] pending-issue Req-delete Issued-none 'uRPF-list(hdl=0x5000021b)'
001210: Oct 4 21:40:08.795 BST: %FMFP-6-OBJ_DWNLD_TO_DP_RESUME: Switch 1 R0/0: fman_fp_image: AOM download of objects to Data Plane is back to normal
001221: Oct 7 23:40:08.310 BST: %FMFP-3-OBJ_DWNLD_TO_DP_STUCK: Switch 1 R0/0: fman_fp_image: AOM download to Data Plane is stuck for more than 1800 seconds for obj[1939605] type[21] pending-issue Req-delete Issued-none 'uRPF-list(hdl=0x50000578)'
001222: Oct 8 03:40:08.281 BST: %FMFP-6-OBJ_DWNLD_TO_DP_RESUME: Switch 1 R0/0: fman_fp_image: AOM download of objects to Data Plane is back to normal
001223: Oct 8 10:40:08.234 BST: %FMFP-3-OBJ_DWNLD_TO_DP_STUCK: Switch 1 R0/0: fman_fp_image: AOM download to Data Plane is stuck for more than 1800 seconds for obj[2253953] type[21] pending-issue Req-delete Issued-none 'uRPF-list(hdl=0x500000d6)'
001224: Oct 8 11:10:08.232 BST: %FMFP-6-OBJ_DWNLD_TO_DP_RESUME: Switch 1 R0/0: fman_fp_image: AOM download of objects to Data Plane is back to normal
Checking the following Cisco doc i found this system error:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/16_xe/smg/xe-16-10/b-sem-16-10-1/b-sem-16-10-1_chapter_010.html
%FMFP-3-OBJ_DWNLD_TO_DP_STUCK : AOM download of [chars] to Data Plane is stuck for more than [int] seconds
ExplanationAn object download from FMAN-FP to lower layer has taken long time. It can be caused by incomplete configuration or software defects
Recommended ActionRun show platform software object-manager fp [active|standby] [pending-issue-update|pending-issue-batch] sorted <min_pending_time> to see the sorted list of update/batch/ command in pending state for more than the min_pending_time. For incomplete configuration, use show platform platform software object fp [active|standby] resolve to see if there is any resolve object
 %FMFP-6-OBJ_DWNLD_TO_DP_RESUME : AOM download of objects to Data Plane is back to normal
ExplanationAn object download from FMAN-FP to lower layer has finished after a temporary stuck. It can be caused by incomplete configuration or software defects
Recommended Actioncheck if there is any functional impact after recovery
Using the commands in "Recommended Action" i don't get any conclusive idea if this cloud lead to a future problem or not.
<catalyst 9500># show platform software object-manager switch 1 R0 object-type-info | i RPF
Object type Name Count Del Pend Layer
RPF_CFG_IPV4 rpf_cfg_ipv4 0 0 24
RPF_CFG_IPV6 rpf_cfg_ipv6 0 0 24
RPF_LIST rpf_list 533 0 24
RPF_LOOSE_SDROP_IPV4 rpf_loose_sdrop_ipv4 0 0 24
RPF_LOOSE_SDROP_IPV6 rpf_loose_sdrop_ipv6 0 0 24
Note: The counter sometimes increment and other times decrement.
After search on the running-config for any feature related to RPF i found this four lines:
<catalyst 9500>#sh run all | i rpf
platform urpf loose counter ipv4 supress asymmetric_only
platform urpf loose counter ipv6 supress asymmetric_only
ipv6 multicast rpf use-bgp
ipv6 multicast vrf Mgmt-vrf rpf use-bgp
The software on the switch is:
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.11.1, RELEASE SOFTWARE (fc3)
BOOTLDR: System Bootstrap, Version 16.10.1r[FC1], RELEASE SOFTWARE (P)
Any one have a clue of what this is?
12 Replies 12
Deepak Kumar
Have you checked this bug CSCvn08705
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn08705/?rfs=iqvred
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Yes i checked the bug that you refer, is related with QOS and the issue is related with uRPF-list.
The switch is running an 16.11.1 and the detailed notes of the bug show this release as a "Known Fixed Releases" so this bug is fixed on my code.
Any other ideia?
Leo Laohoo
Upgrade to the latest 16.12.X rebuild and see if the problem goes away.
Hello Leo,
Reading the release notes of this version (16.12.1) i don't find any resolved Caveats related with this issue.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-12/release_notes/ol-16-12-9500.html
Do you have any evidence that an upgrade to the code will solve this issue?
Raise a TAC Case.
Based on my experience Bug IDs are seldom and/or rarely updated (or accurate).
16.11.X is not a "stable" code.
EdionDiasSage
Hello!
I have the same failure. Have you opened a TAC and did they solve the failure? What have they done to resolve?
Thanks!
What firmware are you running on?
I'm on the most recent recommended version: Catalyst L3 Switch Software (CAT9K_IOSXE), Version 16.9.4.
The issue is auto resolving itself. But I need to know this is something I should be worried about:
SW-SP-CORE_NEW#sh log | i FMFP
Oct 22 18:05:55.936: %FMFP-3-OBJ_DWNLD_TO_DP_STUCK: Switch 1 R0/0: fman_fp_image: AOM download of obj[53053] type[21] pending-issue Req-delete Issued-noneuRPF-list(hdl=0x000004cf) to Data Plane is stuck for more than 1800 seconds
Oct 22 19:05:55.935: %FMFP-6-OBJ_DWNLD_TO_DP_RESUME: Switch 1 R0/0: fman_fp_image: AOM download of objects to Data Plane is back to normal
Oct 22 19:35:55.935: %FMFP-3-OBJ_DWNLD_TO_DP_STUCK: Switch 1 R0/0: fman_fp_image: AOM download of obj[53053] type[21] pending-issue Req-delete Issued-noneuRPF-list(hdl=0x000004cf) to Data Plane is stuck for more than 1800 seconds
Oct 22 20:35:55.937: %FMFP-6-OBJ_DWNLD_TO_DP_RESUME: Switch 1 R0/0: fman_fp_image: AOM download of objects to Data Plane is back to normal
Oct 22 21:05:55.936: %FMFP-3-OBJ_DWNLD_TO_DP_STUCK: Switch 1 R0/0: fman_fp_image: AOM download of obj[53053] type[21] pending-issue Req-delete Issued-noneuRPF-list(hdl=0x000004cf) to Data Plane is stuck for more than 1800 seconds
Oct 23 07:35:55.942: %FMFP-6-OBJ_DWNLD_TO_DP_RESUME: Switch 1 R0/0: fman_fp_image: AOM download of objects to Data Plane is back to normal
SW-SP-CORE_NEW#
Raise a TAC Case. I suspect this is CSCvn08705.
Hello!
I have the same issue using the same release on my C9500-40X. Have you raised a case and did they solve the issue ?
Thanks!
Kiley
Hi there,
I know this post is a few years old; however, I have a 9407 running 17.0.4 with firmware 17.8.1r and I got the same error message as above this morning.  Interestingly enough, the error message indicated a problem with a mac address in our quarantine vlan.  In my case, I was able to find the mac, bounce the port and clear port-security, which cleared the mac address from the CAM table.  The port still showed connected but the mac address did not register with stick mac and was still showing up as a "pending-issue-update".  I then cleared the cam table for vlan 99 and bounced the port again.  At that point, I got a message that issue was cleared and the "Data Plane was back to normal".
Checking for pending issue updates is not something that is part of my normal checks after a reboot but it will be now.
