C9500-16x SVL
edwincharles
Dears,
Does SFP-H10GB-CU1M DAC cable work for SVL and DAD links
balaji.bandi
yes it works when i did test last time 16.12 Code.
BB
Thanks for the response but why its mentioned as below
  • Only Cisco Transceiver Modules are supported.
Since you read cisco document, cisco always suggest to use Cisco SFP and DAC cables always, Since TAC support only cisco products.
if you use any 3rd party SFP and DAC cables, then TAC will not able to troubleshoot if you have issue.
hope that make sense ?
BB
Reza Sharifi
should work fine. From the datasheet:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-11/configuration_guide/ha/b_1611_ha_9500_cg/configuring_cisco_stackwise_virtual.html
  • You can establish SVLs and DAD links on Cisco Catalyst 9500 Series Switches using a combination of modular uplink and fixed downlink ports.
  • You can establish SVLs using 40G or 10G Ethernet connections on Cisco Catalyst 9500 Series Switches and 100G, 40G, 25G and 10G Ethernet connections on Cisco Catalyst 9500 Series High Performance Switches.
  • You can configure up to 8 SVLs in a Cisco StackWise Virtual solution using Cisco Catalyst 9500 Series Switches or Cisco Catalyst 9500 Series High Performance Switches.
